1987 Corvette Z52
Re: 1987 Corvette Z52
It may be a few lbs heavier, but the driveshaft and torque arm are shorter, so I'm guessing the difference will be negligible.
Yesterday the rest of the things to be done outside of the car got finished and the rearend made it's way back into the car. It's not completely bolted in as the new stiffer bushings make it hard to wiggle mounting brackets. So next week we'll have to loosen a few bolts up so we can get it aligned and into place.
On Saturday we spent three hours or so before we realized the C-beam was not going to fall into place and connect the trans and pumpkin together without modification. Somewhere between the aftermarket engine mounts and urethane bushings, the holes will not line up. Yes there was swearing.
Sunday morning I couldn't take losing and went back. I was luckily able to get the beam out of the car without having to remove the rearend again. I spent a bunch of time elongating all eight holes in the beam. On the first try it almost fit, but had to pull it out again for a little finish work.
The beam is now resting in the car, with loose bolts. Next week I should be able to start tightening bolts for good hopefully, and clean up my large mess in the garage.
So all the suspension and beam bolts are tight. The parking brake cables are back in place along with the caliper brackets and also the driveshaft. I also spent a half hour cleaning up tools and an aluminum grinding mess. I would go back tomorrow but Easter festivities are consuming the day.
Next week is the rest of the brakes and the exhaust system. The mufflers will be getting the outer sound deadener installed too.
Good work, muh man. You've been keeping a strong steady pace getting this done!
Thanks! Hopefully within a couple weeks we'll be putting out 11 seconds ETs. I have been thinking about the driveshaft length a little more as I fear it may be a little short. Before I put the exhaust back on, I'm going to pull it back out and get more serious about the measurements. It's a tight window on these VS a passenger car that tends to give a little more slop in the usable length. I just don't want to hurt the tailshaft of this expensive trans, nor do I want to have to pull the trans back out.
My measurements seem to show that the yoke should be fully engaged in the tailshaft bushing, and have more than 1.5" of engagement in the splines. I'm going with it.
Now unfortunately my c-beam modifications have created contact between the c-beam and the driveshaft just at the u-joint area. I did some grinding and loosening, and realigning, and it looks like I now have a little more than 1/16" of clearance. I'm not sure how much I really need here, but a slow test drive will likely tell me if there is a problem.
The brakes are done and the front half of the exhaust installed.
My gut tells me I'm not through with this stupid beam...
Also got the mufflers wrapped with some DEI sound deadening material. More to come.
Since the mileage counter does not function anymore, we're just going to change the oil once a year at this point. It hasn't been probably 1000 miles since we put the Mobile 1 in with the motor swap, but since the motor was opened up, I thought it could use a fresh filter and oil. This time it got seven quarts of Driven LS30 oil, which is what I use in the S10.
Then I got to reinstalling the rest of the exhaust. It didn't go as smoothly as I hoped, but it's on there now. Eventually I'll have to cut and reweld a hanger bracket on the tailpipe itself, but for now it's secure.
Then come the test drive, which was full of questions for me, but after a quick trip through the development and a run around the Bass Lake Loop, it seems like all is well in the mechanical department. We gave it one full throttle blast into 3rd too, no problem.
So now it needs an alignment as the rear wheels are clearly cambered in the wrong direction. I will try to get that done this coming week. I also plan to get it booked in at Hutters for a final tune to get the HP maxed out, the shift points locked in, and the speedo corrected on the Holley screen.
I'm looking forward to putting this thing in the dirt and on the dragstrip at least.
The alignment is now done and set to basically stock settings. The local shop, Federico Tire, has a good alignment guy there. The front is a little off because of the crappy bushings, but it's closer than it was before it went on the rack. Next winter it will get all new bushings and a new alignment. It goes straight and the steering wheel is level. Good enough.
We took the weight bracket off the shelf so we could make a securing rod to keep the weights in place over rough terrain. Since it was originally for a garden tractor, this was not a real concern. Using some old piece of steel off the shelf and a piece of threaded rod, we did some cutting, welding, and drilling and it looks like it belongs there. We just need to paint it and it will be done.
After my alignment I was driving the car and unsure if I felt a vibration from the heavily weighted and easily flatspotted from sitting tires, or if it was coming from my recent driveline work. We dug some good tires off the pile and put them on the rear for a test drive. While driving in Mexico, we were able to get to the top of 3rd gear without any noticeable vibration, so I'll just blame what I felt on the crappy Mickey Thompson tires and the firmly bushed rearend.
Next thing I think I'll do is take the drag tires on the car which are mounted to 16 X 9.5" wheels, and mount them on the 16 X 8.5" wheels for some weight savings.
More to come...
- BP
More to come...
- BP
In the last week or so I got the tires swapped onto the skinnier rims. They're mounted on the car and theoretically ready to race. Hopefully Wednesday will be nice weather instead of another race rainout.
- BP
- BP
So after all that effort the car didn't get any faster.
My trip to the track wasn't a total waste as the car is super consistent and I think the gearing makes it launch more consistently too. It took me a couple passes to trust the track but it was really sticky all night for me. Once I trusted it, I went back to letting the car shift on it's own. I made four runs in eliminations: 12.24 on the brakes (would have likely been a .22), 12.24, 12.24, and a 12.227 in the finals on a 12.22 dial which had a slight tap of the brakes at the stripe and would have been a .21. I ended up victorious in the Street class. The weather was really nice and the track ran without any hiccups. It was fun hanging out with Dave and everyone else we haven't seen since last year (or more).
The car does have a small vibration at speed, so I'm going to chase that after vacation. I really think it's the driveshaft. I'm going to do some very careful measuring and try to have the longer one that came out of the car shortened slightly. I would really like the current driveshaft 1/2" in my mind, and balanced. The shaft that is in there now came with the rearend and really is a question mark as far as it's balance goes.
I really do think there is an 11 second pass here with some good weather. The tune from Hutter's should yield a few HP too. That's coming in mid-July.
Definitely a good start to the racing year.
The driveshaft that was in the car came with the Dana 44 and can be another 3/4" longer than it currently is. And it appears that the front weight was removed for some reason. So im going to have the longer original driveshaft from the Dana 36 shortened to that length and rebalanced. This will give me more confidence that my yoke is in the trans far enough, and should make it smooth as a boob at speed again.
I plan to go to Henderson Driveline on Monday morning after making contact with them.
what is the advantage of having one shortened vs finding a good used one?
Finding the right size would be near impossible IMO. Having it shortened and balanced would insure i have the exact correct length for my customish application, and having it balanced would guarantee that I have a smooth one. Any used one at this point would be a question mark.
