1981 El Camino
Re: 1981 El Camino
If the bottom end is good, there's lots of different combos of these "top end kits" that would get you all the power you need without breaking the bank. And you know all the parts will work together:
https://www.summitracing.com/parts/edl- ... oCnnHw_wcB
Re: 1981 El Camino
Yes, I think that would be the "minimum" option. Gotta tear it down and see what's there in the current engine. If, in the unlikely case, its a roller block in good condition I'd probably do something like that. That's kinda what I did for the roller Windsor that went into my son's '70 F100, although Prestigemoto.com assembled a top end kit for less money than Edelbrock and I also replaced rings and bearings. Slippery slope ...
Re: 1981 El Camino
Finally got at it today, pulling stuff off the engine getting it ready to come out. WXO is coming Monday to get the engine out and apart and see what I've got.
This GM car is going to take some getting used to. :) Think I have it in my head now -- left side odd, right side even. I bet I spent a half hour looking for the last two header bolts till I noticed there are only six on a side. :oops:
I think the engine will come out without opening the AC or power steering if we leave the trans in place. Looks to be enough room to leave the radiator and condenser also in place. Have a new cross member that has a hump on the left side to accommodate duals. Expect we can remove the old cross member, lower the trans to get at the bell top housing bolts, then put the new cross member in when the engine goes back in. Its gotta be a lot easier to change that cross member with the exhaust loose and trans unattached from the engine.
Cyl #8 header bolts are a bear!! I see why guys remove the HVAC unit for some hot rods.
Re: 1981 El Camino
Regarding the gas tank, I have heard that GM sometimes puts an insert in the tank on trucks to move the vent lower. This way when you order a larger tank they just don't install the vent and charge you extra $. This was newer vintage models I don't really know if this is applicable to your El Camino.
Regarding Hooker headers, I've only ever had one set. They were Super Comps and they fit my small block in the Trans Am with no clearancing required anywhere. They were the only aftermarket headers I have ever installed dent free. And they were freaking awesome 1 3/4 pipes ceramic coated. It was 1998 so things may have changed since then! Of course those were on stock head castings. If you are building it to race go with the raised ports and sort out the right headers, but I'm thinking you can probably get the HP you want in a package that fits up to a standard header configuration.
As far a color, I'm partial to blue metal flake with white stripes and gold stars. 8)
Re: 1981 El Camino
WXO and another friend, Jim, came over yesterday and we got the engine and trans out. The under side of the car is pretty nasty due to the leaking oil. Power washed the engine and trans so its not SO filthy. FYI BP, with the dirt removed and a clear view of the casting number the first digit clearly IS a "3" like I said. :wink:
We pulled the intake, heads and pan. It a very clean, flat tappet, two-piece rear seal, 4-bolt main engine. No bosses for a roller-tappet spider. Haven't measured bore and stroke to confirm its a 350 but I expect it is. Cylinders showed a little remaining cross-hatch, some vertical scoring and very little, if any, ridges. Didn't see any overbore, e.g. "030", stamped on the pistons. Maybe that's not common practice any more. Pulled the rear main. Some copper was showing on the bearing and very minor scoring was evident on the crank. Didn't pull the (Edelbrock aluminum) front cover to check the timing chain or pull the cam to inspect it for damage. Assuming the cam is OK, the engine could be resealed, reassembled with new oil pump and timing chain and used as is if boring were the objective. :roll:
Still no plan.
Thought I'd get the engine compartment power washed today but more recovery activity from the check fraud and Valentine Day's shopping kept me from it. First things first.
WXO took pictures.
Not bad for three old geezers. Eh?
Re: 1981 El Camino
Maverick,
Are you sure that you aren't Junior Johnson, and WXO and buddy Jim aren't old
school NASCAR guys??
http://media.gettyimages.com/photos/rac ... ?s=594x594
Re: 1981 El Camino
:lol: :lol: You sensed our fantasy. :lol: :lol:
Re: 1981 El Camino
You can put a lot of moonshine in the back of an El Camino.
Re: 1981 El Camino
BP, hope you know I was joking about the "3" vs "8". Sure looked like an "8" before some more crude was removed and a good look was possible.
Re: 1981 El Camino
Actually, I think that was meant for TireSmoker anyway. :P I don't know much about small block Chevy motor numbers, or any motor numbers for that matter. That's what Google is for...
Keep going with the updates. I love watching other people work! I spent all day Sunday waxing my S10. FINALLY!
Re: 1981 El Camino
Oh, yeah. Tiresmoker. Guess I blew that joke.
Decision
Ordered a 430 HP 383 GM Crate engine from Summit. :D Thought about it for 3 days and pulled the trigger last night. Summit says its "Ready to Ship". I'm Ready to Receive but the EC engine compartment needs work.
Previously ordered a rebuilt Monte Carlo SS steering box and PS pump and hose kit. EC forum says the steering box is a bolt in with quicker steering. Guys that have installed one love it. The 1" play in the steering wheel is mostly, or maybe all, from the steering gear. PS pump and steering gear are both leaking. It'll be a LOT easier to install with the engine out.
Re: 1981 El Camino
That will be so sweet when installed, plus no real modifying / fabricating to make it work. Perfect!
Re: 1981 El Camino
Jim, is that a GM SP383? That's basically the same engine as the zz383 in my Chevelle. It runs and drives great!
Good call on the steering box too. I'd like to do the same swap on the Blazer.
Re: 1981 El Camino
Dave,
I ordered Summit part number "BP383" Blueprint Engine. https://www.summitracing.com/parts/mll-bp38313ctc1
The "SP383" GM Performance Engine at Summit is https://www.summitracing.com/parts/nal- ... /overview/
BP383 is $600 less and includes carb and dist, cast crank and single plane intake.
SP383 includes forged crank, (now includes) single plane intake, water pump but no carb or dist. Strange that it's listed as 5 less HP?!?! It may have roller rockers judging by the valve covers which would have been nice.
Actually, I didn't look at the SP383 but if I did I would have chosen the BP383 because of the dual plane intake and $600 lower price.
Expected delivery is 1-5 days with additional delay for residential address. WXO and I are pretty pumped up about it.
Got the engine compartment power washed yesterday. Today I'll work on the steering gear replacement. I probably don't have a puller that will remove the Pittman arm. Maybe Autozone has a loaner.
JIm
