2005 Yamaha Raptor 660
Re: 2005 Yamaha Raptor 660
Haven't posted here in awhile. The Raptor was solid this season, but the last couple races were showing some clutch problems shifting through the gears under power at the dirt races. I really had to granny shift, which is not conducive to winning or good ETs. At least I'm hoping it's the clutch... So I have new clutch guts on the way that should be a mild upgrade to the 20year old stock one in there. And since I like going faster, I ordered a Stage 2 HotCams cam and valve spring kit for it too. I'm hoping this should be good for maybe 4-5HP over stock, which is not insignificant. Hopefully take advantage of the good exhaust I already have.
And if that all goes according to plan, I will be doing something about extending the swingarm. Either making this one longer or buying an aftermarket. I'm shooting for a +4" longer arm, which should really let me launch this thing.
More to come.
About a week ago I got the Raptor back from Camaro Bob who did the cam swap and clutch install. I have not ridden it as the roads are covered in salt and the yard is covered in snow. The carb will need to be retuned, which I will do when it warms up some. As of right now it's sitting on the trailer in my heated storage unit. I may order a swing arm in the next few weeks and bring it back home to do that install in a couple months. I heard it run, and it doesn't sound much different than it did when it was stock, but I expect once the RPMs come up, it will be noticeable.
