2020 Ford Ranger #55
Re: 2020 Ford Ranger #55
No doubt about it, when it's clean Black is the most awesome color!
The Ranger looked ok before it was washed, but now it's one sweet lookin' ride!
The Ranger turned 10,000 miles yesterday. So far it has been basically trouble free and has done a great job being a real truck. I regularly carry 1200-1500 lbs in the bed and it does an amazing job towing also. I've only had one tank under 20mpg and that was towing the Firebird to Mid-Ohio and back (19.9mpg).
I am contemplating getting the factory performance upgrade once I'm done with the storage bays. I've also considered buying a new Maverick too, but at their best will only tow 4000 lbs which won't pull a car. I like the slightly smaller size though. I'll probably just keep it as it really seems super capable for it's size, and with the tune should be in the 13s which is super strong.
Today the Ranger got a synthetic oil change (Mobile 1) at 11996 miles. It was about 5300 miles since the last one and since it's been working pretty hard lately, and it was nice out, I decided to get it done.
I recently bought a new MBRP exhaust for it also, but it's still in the box and probably will be until about May when I finish the storage unit project. According to the dyno specs, it should be good for 15hp and 15lbft. Plus it should sound a little better, but not loud in any way.
https://mbrpexhauststore.com/3-cat-back ... 2019-2021/
Re: 2020 Ford Ranger #55 - UPGRADES
So on Sunday morning I went to Kevin's to install the new MBRP exhaust. It went on as designed in a little more than an hour. The only issues with the install were that the band clamps were bent weird at the ends and I had to really crank down on them to be able to get them tight around the pipe. Then after I drove it a couple times I had to tighten them down again with a warclub to get them to finally be tight. I also had to trim a piece of steel off one of the side hangers that was hitting the frame. It sounds as expected with a little extra noise at idle and at WOT, but under normal cruising you hardly even notice, which is perfect. All by itself though, I didn't really feel much of a difference performance wise, but the mileage on the truck has already begin to get better, which I read would happen based on some owner's reviews.
Then today I went and bought a performance air intake kit from the hardware store, in the form of 2.5" shop vac hose. The stock factory air inlet at the airbox brings in fresh air, but is about half the size of the hose that takes the filtered air into the turbo system. So I figured if I just increase the amount of air going in, things would get better, and I was right. The truck feels WAY better now. So between the intake and exhaust, it's much happier IMO. We'll see what the tale of the timeslip says, but I'm expecting to be in the 14.1x's somewhere if I can still get it to hook up. Best so far was 14.44.
To make my little creation, all I did was poke a 1-7/8" hole in the box, then open it up slightly more with the die grinder, just enough for the flexible hose to go in. Then I cut about a 15" piece of hose and ran it to a place behind the headlight away from heat where it's getting basically fresh air, and put it all back together. Doesn't make any more intake noise, but I heard my turbo working under load for the first time, so I'm guessing it likes it. I wish it wasn't wet out today, cuz I couldn't keep traction anywhere in 2nd gear, and that's never been a problem before, even in the wet.
This should keep that pesky GMC Terrain off my back for awhile... :mrgreen:
I love inexpensive, improvised improvements!!
Somewhere along the line I acquired a shop vac hose with no relevant vac. It could have done the job maybe and got it out of the way. So it waits a while longer to meet its destiny lol.
Nice upgrades.
Today the Ranger got a fresh coat of wax. Yesterday I scrubbed the bed out and scrubbed the WeatherTech floor mats too. Both of things were overdue and it hasn't been waxed in over a year. What a difference! I also treated the tonneau cover since it's never been done. The truck will slide back into a much easier lifestyle now that the storage scavenging is complete.
Almost a year since my last post. Recently turned 20k miles. I did reclean the interior since there was dog hair everywhere and the floor mats were a wintery mess. I re-sprayed the rusty parts of the frame and hitch that you can see with semi-gloss black. The summer tires went back on a few weeks ago too. It's due for an oil change at around 21k miles. So far it's been a good truck.
Oil change today at 21005 miles. Still using oil I got from the Dave Bales collection. Last change was Quaker State, this time it's Mobil Synthetic. I'm super easy on this thing, and there's always about 30% oil life left, so I'm not too concerned about the brand of oil, as long as it's synthetic and the right grade, I'm good. It got a Motorcraft filter since Walmart had one in stock this time. Lubed all the hinges and locks, and topped off the washer fluid.
I was disappointed to find absolutely NO way to check the oil pressure on this thing. I went through a bunch of menus and nothing. So I got the book out to find out it literally has an idiot light, like a 70s car, and worry about it if that comes on. So sad that we're headed backwards with stuff like this.
The Ranger is around 30500 miles right now and is about six months out of bumper to bumper warranty. Drivetrain goes to 60k I think. I tend to get antsy after this period for a new ride and came close to buying a 2024 Durango RT. I just couldn't swallow the $33k difference in cost between the two vehicles. Not yet at least, so I decided to keep the Ranger and do a couple upgrades. Last night I ordered this for it:
https://www.summitracing.com/parts/BEL-1044SP
Lately the truck has been SOOOO wallowy driving around so I was going to do new shocks and struts as I'm sure the factory ones are garbage at this point. Then it hit me that they might finally have a lowering kit available (which they didn't for these trucks when I bought it) and they do. This should definitely stiffen up the old Buick ride and make it look like it's not driving downhill everywhere I go. The added bonus will be for loading and unloading as my tailgate right now is basically at 3/4 ton height, which is annoying.
I'm also going to get a set of used 18" Ford Ranger factory wheels and get a little more sporty tire for it, again to help tighten up the feel of the truck and maybe look a little more correct with the lowered suspension. My factory summer tires only have probably 15k miles on them but they've been junk since new and are pretty wore anyway, so it was going to need tires anyway.
The other thing I'm going to do is get a performance tune for it. Ford makes one, as well as some other guys, but the Ford one comes with a powertrain warranty (need to learn the specifics there). You can read about it here, but it's pretty significant power upgrades which should make it more entertaining to drive. I drive it pretty soft right now, but when you want to go, you want to go!
https://performanceparts.ford.com/part/M-9603-REB
Similar to this:
The lowering kit is now a bunch of boxes in my garage. Paul should be able to do it in the next few weeks, if not, I'll go another route. Without a long boring story, I bought some 18" chrome factory wheels to go on once it's lowered. I'll order the tires in the next couple weeks. The tires should be about .4" shorter and almost 2" wider than the stock ones I'm running now. The size is a 275-55-18 assuming I can find them. Kuhmo makes a set but not a lot of people carry them.
Been awhile since my last Ranger post. The lowering kit is still in the garage, but I have Camaro Bob lined up to do the install probably in the next few weeks. I got the 18" chromes mounted to my new 275/55-18 tires awhile back too, but was hoping to put them on when it was getting lowered. That didn't happen, but since I have a mild trip planned this weekend, I didn't want to do it on snow tires, so I broke out the chromes. I think they look better than I expected, but will really look correct once it's lowered down.
I also pulled the spare tire down, which is something I have never done. I cleaned the dirt and crap out of the rim, filled it to 45psi (it was at 22psi), sprayed some lube inside the tire crane and also around the inside of the rim where all the crud gathers, and put it back. Hopefully I never need it, but it's ready again. The snow tires got cleaned up and put back on the shelf until fall.
I got out the semi-gloss paint and touched up all the annoying rust spots that appear on the frame and hitch too. They make it look so ugly.
At some point sooner than later, I'll get to giving it a good old fashioned detail job too. So far it has been good at being my truck.
Well, we were finally able to get the lowering kit installed on the Ranger. I think it looks so much better. Having everything lower makes this truck so much more operator friendly too. Easy to get in and out of, loading in the back is almost as low as my S10, and I don't think I'll need a ladder to wash the roof. It rides a little more firmly, which is to be expected, but there's no ridiculous head toss anymore and it handles way better.
The factory rear shocks were already leaking, and although the front were holding their fluid, they were cooked too. I need to set up an alignment for my next step as the camber is a little out of whack. Otherwise it drives straight and true. Bob was real good about putting it back as close to spec as he could. He had to modify the tailpipe exit too, but did a nice job there too.
So far, pretty satisfied with the product.
Today the Ranger got new spark plugs. Not sure if there is any measurable difference, but the old ones did show some wear. Truck has 36666 miles on it. After the Vette is done, I'm going to have Bob raise the front end one inch and hopefully adjust the camber back to a stock location. It seems to have settled a little since the lowering job in the front, and has too much rake for my liking, plus at the lower setting, the correct camber angle can't be reached. I just don't like the look of the tires cambered in so far.
