Chip off the old block
Re: Chip off the old block
You mean to tell me you didn't polish the inside?? That would help the air pass over the surface faster... Just kidding. That thing looks amazing! Looks like the whole rig is about ready for some fuel and air.
Racin'Jacin
Post by Racin'Jacin »
BP, I thought of that TOO LATE!!!! Next one I might have to polish the inside before I weld it!!!!! We'll call this one - "engineered turbulence" used to enhance atomization!!!! :-) Almost ready still need to come up with some throttle/idle stops/adjustments. That and find the optimal nozzles - these are only for fitment. And I need to make up a fresh set of hoses! :-)
I want to know what you are going to make the hoses from?
Racin'Jacin
MostMint wrote:I want to know what you are going to make the hoses from?
2 or 3 people manufacture the high pressure hose. After some searchin' I finally found out who sells the ferrules cheap. From there it's just re-cycling and cleaning the ends and roll crimpimg the ferrules. Easy Peezy
I was just wondering if you might become #4 manufacturing the hose. I'm sure that stuff is expensive. :lol:
Your creation is fantastic
Racin'Jacin
I would definitely make the hoses up if someone needed them, but I need to find a supplier for the fittings. Which I once did, but lost the bookmark. In the meantime I just recycle the ends. Thank you for the kind words. I am really happy how this is coming out!!!!!
Racin'Jacin
Project "Jay Scott" AMF Fuel Injector is nearly done. I can't wait to test it. In the meantime I made a video of the process. I'm not much of a photo editor!!! So please be gentle! :-) https://youtu.be/tO5n-sCNIsA
Wow! It's been a fun project to follow.
Amazing stuff, I sure enjoyed it.
Can't wait for the next whatever.
Racin'Jacin
Fred32v wrote:Wow! It's been a fun project to follow.
Fred, thanks! Sometimes the hardest part is trying to decide what's next!!!!
This is amazing! Seriously.
Racin'Jacin
Basement Paul wrote:You mean to tell me you didn't polish the inside?? That would help the air pass over the surface faster... Just kidding. <snip>
Dammit Paul! I was thinking the same thing, but it's SUPER hard to polish the inside once it's together! So NOW because of YOU - I had to make ANOTHER whole unit!!! It's ALL your fault (kidding) ha ha ha
Still needs more polishing
Not quite done
Not quite done
Pre-polished just to make BP happy!
Ha HA! I love it!
Racin'Jacin
Shiney! Still lots of polshing to do.
Racin'Jacin
Slightly "trick" barrel valve. I can't divulge the trick feature just yet, but here's a sneak peek. To be continued.
Racin'Jacin
Been playing around making a couple of these. More to them than it looks. Super tight tolerances. Multiple "ramps", lots of fun.
Haven't tried to heat treat one....yet, but I will. Fingers crossed!!!!
