Project: Cheap Bastage - Transmission Rebuild/Repair
Ok so the next chapter in Operation Cheap Bastage is the rebuilding of the transmission for my old Rambler Convertible. The trans has been "acting up" for the last couple years (yeah I know - can't rush into these things) anyways I scored a spare trans at Canfield and it's been sittin' long enough so I decided I'd finally get off my dead arse and have a lookie see.
The trans is a BorgWarner T35 aka Flash-o-matic 3 speed automatic.
While it was a mess inside (dirt mostly) mechanically speaking it was in pretty good shape. I put new frictions and steels, seals etc and then I ran into some issues. First one of the valves in the valve body was badly pitted - it was definitely a dead palyer. At first I scoured my bin of drill bits looking for a donor the right diameter, but the only one I found wasn't suitable - damn stampings right where I need it smooth. So my buddy brought me a chunk of drill rod. I machined it close (.001" over) heated it cherry red and dunked it in oil. It hardened up nicely. I then polished it to the appropriat size and VIOLA - I'm in business!!!!
While I was all busy pattin' myself on the back - I next proceeded to put a nice scuff mark into the annular piston from the front clutch drum - son-of-a &^^%$#!!!!!!
After calling around I actually found a NOS one for 11 bucks!!! How sweet it is baby!!!! So this time I decided I'd be extra extra careful assembling it - and naturally I F-ed it up AGAIN!!!! *&*&$$*($#$#^%*(_!!!!!!
OK - I give up - so I grabbed an old piece of water pipe and proceeded to machine a steel repair sleeve to press into this piston - a machined in a small head on one side so I'd not have to worry about it ever moving out. It came out pretty well. I next pressed it into place and this time I measured to every turn of the nut to make sure it was seating squarely every second! Viola!! It went together as it was supposed to!!! Finally!!!
I think it'll be ok, but only time will tell. I'll update this when I finally get the trans swapped into the car!!! Wish me luck!!!!
At least I still have the (sick) trans incase I goofed this one up without knowing it!!!! :-)
To Be Continued...
Cheap Bastage
Well, after Murphy did his best to bone me I finally got the "new" trans swapped in (after a last minute output shaft swap) and cruised it home from my buddy's shop last night. It was a tad cold, but it seemed to work fine!! woo hoo. I have yet to go out this morning and look for any leaks - I'll keep my fingers crossed.
Operation Cheap Bastage Trans Reuild
Well I checked the trans the following morning and much to my dismay there was a pretty good sized puddle of ATF underneath the car!!!
As I envisioned all the possible crummy scenarios - yanking the rear end to yank the driveshaft to yank the trans I ultimately found that the trans gasket must have taken a "set" and allowed the weaping of fluid. I retorqued the bolts - wow they were very loose and so far so good. I think have to keep an eye on things for a while.
So far Operation Cheap Bastage Trans Repair has proven sucessful - I hope I don't jinx myself by saying that.
Maybe now I can get off my dead a$$ and start planning Operation Cheap Bastage - Engine Rebuild.
My buddy suggested that I consider tossing this bizzare rear end and goofy driveshaft and convert eveything over to an 8 or 9 inch rear - I gotta say I wouldn't mind that - something to keep in mind.
Probably before that I need to fix the BENT driveshaft that we discovered - explains that goofy vibration I've been searching for awhile now. ;-0
Ok, Racin, we've been reading a lot about the repairs you've been makin' and seen a few parts here and there, but we have yet to see a picture of the actual car which the reason for all this work. What d'ya say? How about a few pics of the car?
Project Cheap Bastage - Evidence
Pics? Sure I got some here somewhere....
You can see us crusin' around Willowick quite often - usually up to Jerry's or CP's to get the kids some Ice Cream cones - it's a family tradition!
BTW - this is the only car that I have that I try to keep pretty "stock" looking - I mean I'm not a fanatic about it or anything like that - I have upgraded to disc brakes, custom collapseable steering column, HEI ignition, and so on. And believe me when I say, " I GOTTA LOOSE those bias ply tires!!!!!! QUICK!!!"
Love the car! But do you drive it from the back seat? That's a pretty small car.... :)
Mr. Racin'..... Love the drop top!!! I think that I detected an emergency brake lying on the ground under the passenger side front wheel in the top photo. Is that a factory option, or just an add on????
Operation cheap Bastage - Trans Repair
Paul, What do ya mean! By today's standards it's a big car! Hey if you think THAT looks small - you ought to see one with a hemi stuffed in there - thank god for TILT front ends!!!! (My other one has a 392 Hemi in it - it's a hardtop - my first car had since I was 15)
GMJohnny, that pic was from awhile ago - so I can't remember why I had a block there unless it was just coincidence - after all it's an automatic!!!
It's been a great family car - kids love it!!!
