TECH TIPS
TECH TIPS
Hey Guys, Is there a TECH TIPS area here?? I didn't see one. Anyone else like the idea? Maybe we could learn some stuff from each other?
Here's one to start it off. My buddy at work showed me this - it has saved my butt SEVERAL times.
TIP: Take some of your solder and wind it around the end of your soldering iron's cord. When you can't find your roll of solder or are otherwise indisposed - your "stash" of solder is EXACTLY where you need it - with your soldering iron.
I second that motion, Tech Tip section or "how To" section
Anything we had up to now would be in the reference section
Tech TIPS
SO If I (or anyone else for that matter) wants to post more - should we be putting them over there?
TheRookie
Post by TheRookie »
How about just putting them in the reference section? That was meant for references to Tech Tips, etc. Close enough or rename that section.
Re: Tech TIPS
Racin'Jacin wrote:SO If I (or anyone else for that matter) wants to post more - should we be putting them over there?
I keep waiting for a final ruling from Tiresmoker on this, but that is what I recommend until or unless he decides otherwise.
