Page 1 of 2
C6 Corvette
Posted: Tue May 13, 2025 8:08 am
by markss327
Well..... I did a thing.
2007 3LT Auto
42k miles
More to follow.
Re: C6 Corvette
Posted: Tue May 13, 2025 7:36 pm
You did the right thing!
Re: C6 Corvette
Posted: Thu May 15, 2025 9:07 am
Is this a motorcycle replacement, or just an addition?
Re: C6 Corvette
Posted: Mon May 19, 2025 8:23 am
by markss327
Unfortunately, this is a motorcycle replacement.
The FJR is for sale. :(
Re: C6 Corvette
Posted: Mon May 19, 2025 11:53 am
by markss327
More info as promised.
2007 C6 Corvette Convertible. 3LT. Automatic. Lemans Blue with two tone gray interior. 42K miles. I'm the 5th owner. No accidents, per Carfax. At the dealership were purchased, I was able to get this on a lift and examine the undercarriage. All original. Unmolested! No evidence of being high centered. All CV boots intact. Good brakes. The front air dam is par for the age/mileage. The LS2 does show evidence of a oil pan leak. That was a good price negotiating tool. Trans and diff are clean.
500 Mile report:
It passed an E check. :) :) :) :)
So far, so good. Averaging 22.1 MPG. The battery was new in March ‘22. The tires (Michelin Pilot Sport All Season 4) all have the date code of 4321\4521. The tires still have the little mold nubs on them! The oil life monitor says 55% remaining, yet it was just changed at the dealership when I bought it, obviously never reset. There’s a little sticker in the windshield stating the oil change, mileage and date. The filler cap door has a nasty scratch in it. But I think I can live with it.
The paddle shifters are kind of fun to play with !!!
The heads up display has a street mode and two track modes, and another thing kind of fun to play with. I've hit .42Gs :mrgreen:
So far, I’ve had it up to 95. Steady as a rock.
I’ve done two rolling full throttle blast on freeway ramps from RT91 to 422. Very gentleman ‘ish’ acceleration. Nothing violent, it just pulls like hell. Traction control was still activated….. Nothing from a standstill.... yet.
The limited slip differential has a little chatter when it’s cold going around tight corners. I’m betting the fluid was changed, but the special additive for the clutch type limited slip was never added.
There’s a cover missing on top of the air intake/filter system. I’m not quite sure how important that is, if at all.
I’m still sorting out the memory seats and the key fobs.
The harmonic balancer will probably need replaced at some point. Common issue I understand. Shes a bit wobbly. :roll:
Re: C6 Corvette
Posted: Mon May 19, 2025 7:38 pm
It looks like a nice bike replacement. The oil leak may be as simple as snuggling up the pan bolts. These things do not leak.
It's funny that when we're older, we like to say how good the mileage is, and when we're younger, we liked to say how bad the mileage is.
Any plans for any performance upgrades or is stock good enough for you?
Re: C6 Corvette
Posted: Tue May 20, 2025 8:22 am
by markss327
One of the reasons I bought this, is because its "unmolested".
No tune, no cam, no headers, no cat-back etc.
It's going to stay that way.
While in the hunt, I drove a 2008 (I really wanted an LS3....) 'vert, had a BORLA, pedal commander, aftermarket radio, and a back-up camera and only 21k miles. All the while I was driving this, I couldn't help but think about the possible wiring mess behind the radio. That was a showstopper.
Anyway.... my climate controls are now 'flashing' indicating emanate failure. I understand this is a relatively easy fix. RnR of the control unit. In the meantime, the AC is still functional so it's not real high on the priority list.
However, an alignment is. Shes got a slight pull to the left....
Re: C6 Corvette
Posted: Tue May 20, 2025 1:31 pm
That looks really good Mark, congrats on the purchase. Will we eventually see it at Thompson??
I think my motorcycle riding days are about over too.
Re: C6 Corvette
Posted: Tue May 20, 2025 2:30 pm
by markss327
It WILL be at Thompson, as soon as I get a plate. (waiting on the title....)
I don't wana be 'that guy' with a 'Vette and a 30day tag, at the track!
PS-
Thanks for moving this!
Re: C6 Corvette
Posted: Sun May 25, 2025 1:22 pm
by markss327
The Yamaha is now sold. Bittersweet departure.
At least I get to concentrate my time and energy (and finances) to the C6.
Items needing addressed are:
Engine oil and filter change
Transmission filter and fluid change
Differential drain and fill
HVAC head unit will need attention. I get an intermittent flashing display
Harmonic balancer needs replaced. New serpentine belt
All items are within my skillset, but I need to get under the car.... :roll:
Looking at getting some kind of portable lift. IE, Quick Jack kinda thing.
Any recommendations, or anything I should avoid?
I've reached out to the Corvette Museum for a build sheet and window sticker.
I did a RPO code search (via CorvetteSalvage.com) and got this:
If anyone has a better source reference, please advise.
RPO Definition
AAB MEMORY - DRIVER CONVENIENCE PACKAGE
AJ7 RESTRAINT SYSTEM - SEAT, INFLATABLE, DRIVER & PASS, FRT & SIDE
AL0
AQ9 SEAT - FRT BKT, LUXURY
BGR PLANT CODE - BOWLING GREEN, KY, USA
CJ2 HVAC SYSTEM - AIR CONDITIONER FRT, AUTO TEMP CONT, AUX TEMP CONT
CM7 ROOF - CONVERTIBLE, FOLDING, POWER
DD0 MIRROR O/S - LH & RH, REMOTE CONTROL, ELECTRIC, HEATED, LT SENSITIVE
FE1 SUSPENSION SYSTEM - SOFT RIDE
FE9 CERTIFICATION - EMISSION, FEDERAL
GM8 AXLE REAR - 2.56 RATIO
IL6
JL9 BRAKE SYSTEM - PWR, FRT & RR DISC, ANTILOCK, FRT & RR WHL
KAI HEATER - SEAT, FRT
K63 GENERATOR - 110 AMP
LS2 ENGINE - GAS, 8 CYL, 6.0L, SFI, ALUM, GM
MX0 MERCHANDISED TRANS - AUTO PROVISIONS, O/D
MYC TRANSMISSION - AUTO 6 SPD, HMD, 6L80
NK4 EMISSION SYSTEM - EEC 05
NT7 EMISSION SYSTEM - FEDERAL, TIER 2
N37 STEERING COLUMN – TILT, TELESCOPING
QX3 WHEEL - 18 X 8.5 FRT & 19 X 10 RR, CHROME, FLANGLESS
R6K
R6P
R9N
SLM
UE1 COMMUNICATION SYSTEM - VEHICLE, G.P.S. 1
UG1 OPENER - GARAGE DOOR, UNIVERSAL
UJ9 INDICATOR - LOW TIRE PRESS, VAR 2
UK3 CONTROL - STEERING WHEEL, ACCESSORY
US3 ANTENNA - DIVERSITY
US9 RADIO - AM/FM STEREO, SEEK/SCAN, RDS, MULTIPLE COMPACT DISC, AUTO TONE CONTROL, CLOCK, ETR, MP3
UV6 DISPLAY - HEAD UP
UK2
U52 CLUSTER - INST, ELECTRONIC
U65 SPEAKER SYSTEM - 7, CUSTOM
VA5 LANGUAGE LABEL - ENGLISH
UDD VEHICLE INFORMATION - DVD, CUSTOMER ORIENTATION
VK3 LICENSE PLATE FRONT - FRT MOUNTING PKG
V73 VEHICLE STATEMENT – USA/CANADA
XBH
YPI
ISZ
I9U
3LT
4IT
84I
846
Re: C6 Corvette
Posted: Sun May 25, 2025 4:18 pm
I always giggle when I see a 2.56 gear ratio on a modern car. That thing should be a 3.56 and it would still be able to do 150+ and cruise easily down the freeway.
Re: C6 Corvette
Posted: Sun May 25, 2025 4:44 pm
by markss327
I know..... :roll:
1500rpm = 70mph.
Re: C6 Corvette
Posted: Mon Jun 02, 2025 12:04 pm
by markss327
1k Mile Report.
Well, that didn't take long.
No new issues to report. Still figuring out the memory key fobs. I'll eventually read the manual...
23.1 mpg average. Must be that 2.56 gear :lol:
Got my title. 14days after the sale.
The Harmonic balancer is on the top of my list to address.
Looking at portable garage lifts.
Quick Jack has a 5000lb unit that will work on all my vehicles.
Re: C6 Corvette
Posted: Tue Jun 03, 2025 7:52 am
That license plate frame will get you some street races for sure.
Re: C6 Corvette
Posted: Tue Jun 10, 2025 8:10 am
by markss327
Peaking around under the hood...... Cabin Air filter.
Filter is obviously not salvageable. Picking up a new one today.
Damn rodents. :evil:
The carnage looked aged. Probably over a year or two old. So far, I'm not able to find any other damage.
