"Car" #46
Posted: Tue Dec 04, 2012 9:28 pm
Taking up more of my time is my newest acquisition, a 2003 Blazer ZR2. I bought this one just over a month ago and have been so busy with working on it, my S-10, and the Caddy, that I haven't had too much time to get online and post about it.
The Blazer has 89k miles on it, and is pretty much as loaded as they came with a sunroof, 6CD in dash changer, power seat, and steering wheel controls. Overall it's in pretty nice condition, with a few little paint bubbles just in front of the rear wheels (a common problem with these). When I got it it was missing the front lower valence and fender flare extensions attached to the bumper.
Since I got it, I've given it a complete wax job, RainX'd all the windows, replaced the lower valence and fender flare extensions, replaced the rear spare tire cover, installed new spark plugs, wires, cap & rotor. I bought a new K&N (yeah K&N) replacement air filter off ebay, and drilled out the air intake opening (it's about 4" now) in the airbox. I installed a throttle body spacer also to help improve mileage (I'm barely over 17mpg for now). I also cut down the damper on the underside of the throttle blade to help increase throttle response. Last week the mass air flow sensor took a dump, so I pulled the one off my S-10 and put it on. The S-10 got a new Granitelli one which is noticably larger and helped push my boost to just about 10psi from just under 9psi.
I don't have a good picture of it yet, but look below to get an idea of what I'm talking about. I like it because it has the factory off road package with 31" tires, a factory lift kit with real skid plates, locking differential, Bilstein shocks, a bigger 8.5" rear axle, and 3.73 gears. I also painted the hitch and front hooks, and the spare tire latch (a big bracket on the tailgate).
The only problem it has now is that it leaks engine oil. The longer it sits without driving it, the worse it leaks. I haven't researched it yet, but I'm guessing there's something wrong with the oil pan (aluminum cast).
