Page 2 of 14
Re: 1979 Malibu
Posted: Fri Nov 12, 2021 2:42 pm
Small, but important step of progress made today...
Re: 1979 Malibu
Posted: Fri Nov 12, 2021 2:55 pm
by Blue_69_malibu
Baby...it's cold outside!
Where did you put the Chevelle?
Re: 1979 Malibu
Posted: Fri Nov 12, 2021 3:08 pm
I took it over to 12931 and put it in the garage!
Re: 1979 Malibu
Posted: Fri Nov 12, 2021 3:32 pm
by Blue_69_malibu
Next to the Grease Gun?
Re: 1979 Malibu
Posted: Fri Nov 12, 2021 3:57 pm
Looks fast.
Re: 1979 Malibu
Posted: Sun Nov 14, 2021 12:53 pm
Basement Paul wrote:Looks fast.
You wanna see FAST?
Spent some time cleaning up the engine bay. I got some crud removed from the frame/cross member, but still have more to go. I sprayed everything down with a good soap/water mix, some foamy engine brite, and then hit it with the pressure washer. I think I might need to still wire wheel a few things. Once everything is cleaned up, I'll hit it with a fresh coat of black. I also wanna replace that duct-taped radiator overflow.
Re: 1979 Malibu
Posted: Sun Nov 14, 2021 4:13 pm
A layer of black paint would tighten it up for sure. I like the whole vibe of that car though.
Re: 1979 Malibu
Posted: Thu Nov 25, 2021 10:49 pm
I've done a bunch of cleaning and some painting in the engine bay. I removed the crappy radiator overflow and will look for another. If I can't, I wonder if I could pull off all the duct tape and paint it with some FlexSeal and see if it would hold?
I'm trying to find a diagram for where the main wires are going into the fusebox. Theres a lot of good ones over at maliburacing.com, but not quite what I need.
Re: 1979 Malibu
Posted: Thu Nov 25, 2021 10:58 pm
If you can’t find an OE replacement maybe you can get an aftermarket overflow bottle.
Re: 1979 Malibu
Posted: Fri Nov 26, 2021 6:47 am
I have this if you think it can be helpful to you:
Re: 1979 Malibu
Posted: Fri Nov 26, 2021 10:37 am
Thanks Walt. This is a '79, but I'm guessing 79-84 are somewhat similar? What I'm really trying to figure out is which wires are what on the engine-bay side of the fuse block.
edit: this link to the gbodyforum.com has the info I need. Linking it here for documentation.
https://gbodyforum.com/threads/79-malib ... ram.84386/
Re: 1979 Malibu
Posted: Fri Nov 26, 2021 11:03 am
I have this diagram for my Chevelle (bought it, its great) , and in one part, it shows the connecter on the engine bay side and all the different wire functions/colors and which terminals. Unfortunately, 1979 is too new for classiccarwiring.com.
https://classiccarwiring.com/products/1 ... 5643821256
Re: 1979 Malibu
Posted: Fri Nov 26, 2021 11:47 am
Here's the pinout info for the bulkhead connector (1984 version)
I'm not sure if it will be helpful or not.
Re: 1979 Malibu
Posted: Fri Nov 26, 2021 12:19 pm
THANK YOU! I'll run out later and see if it seems to match up with what I have.
Re: 1979 Malibu
Posted: Sun Nov 28, 2021 1:44 pm
Unfortunately, nothing in this seems to really match up with what I'm seeing in my car. But thanks for posting it Walt.
Engine compartment starting to shape up a bit.
