408 resurrection / potluck
Re: 408 resurrection / potluck
Here ya go, some video goodness.
One lesson I've learned -- new engine, new tune file. When we first went to fire it yesterday, I was pretty frazzled, I hadn't really prepared to actually start it that day, so we mucked around with the zz383 tune, changing the engine size, but keeping most everything else. It took a bunch of farting around, including starting fluid to finally get it running, then took throttling to keep it running until I could get some auto-tune going to help out.
The video you see today was after 1) getting some sleep! 2) generating a new VE table, and just slowly going through and changing some key startup settings like the cranking fuel. It started and ran (very rich) on the 2nd attempt, I was able to adjust the idle area real quick to sorta even it out, let it get some heat, and this video was the next startup after that. It felt like "wow, i kinda know what i'm doing here!"
I'm pretty excited..
I really enjoyed your fire up video.
There are few things that are more exciting than that first startup
and more satisfying when there are no problems and the tune comes in.
Great job, looked like it was a crazy fun weekend.
Maybe it's time to finally install these. I think I got them at Carlisle. They've been in a bag on a shelf for a long time. The white would match my stripes. :-)
If a picture is worth a few words, this is how today's first quick test drive ended. Knocking, badly.
it's Boba Fade and the Millenium Flatbed to the rescue!
Bummer
[quote="MostMint"]it's Boba Fade and the Millenium Flatbed to the rescue!
We’ve all been there. ^^
Yes, but doesn't she look good up there on the Millennium Flatbed!! :D
wxo wrote:Yes, but doesn't she look good up there on the Millennium Flatbed!! :D
Like a queen being escorted back to the palace!!
#2 rod. That was the same one that had the bad/wrong bearing last time.
ugh. that looks like the rod cap bolts backed off? there is no break in the rod or cap.
Yup, thats what it looks like. I found both nuts and they look fine.
How does the crank look??
GMJohnny wrote:How does the crank look??
Like it got in a fight with a rod. Double KO.
seems likely the rod cap bolts somehow got stretched or they were not torqued correctly.
