The most significant project is my new cylinder heads. I bought a set of Edelbrock E-Tec 170s from Summit. I really agonized over this decision. Money-no-object, I would've bought AFRs. But money was an object, and from everything I read, it seemed like it was going to be $1700+ for the AFRs. The E-Tecs were $1060 + tax. In Super Chevy's "Danger Mouse' series (April '05), using a 234/238 cam, they made 487 HP @ 6000 / 456 ft/lbs @ 4800 with these heads. On a 355. My cam is similar.
My biggest concern is that it appears I will have 10.9 or 11:1 compression. I'm not paying for racing gas, or even 94. It needs to run on 92-octane. With the heads being aluminum, the more 'efficient' combustion chamber and the EFI, I *should* be ok.
Doing more research this winter, I think I now will be able to successfully implement the ignition control on Megasquirt. The same tunability I have on the fuel side I will now have on the ignition side.
As these are a Vortec-style head with a new intake bolt pattern, I also bought a new Stealth Ram intake. I managed to get $400 for my old Stealth Ram setup, so it helped keep costs reasonable.
In addition to the heads and intake, I also picked up a set of 1.6 roller rockers to replace my 1.5s. This should bring my cam lift from .488/.510 to .520/.544 (234/244 @ .050"). I thought long and hard about adding a roller cam, but decided that the additional $1000 would probably be better saved towards a 700R4.
With the significant amount of work under the hood, it made perfect sense to re-wire the engine. My old harness, while functional, was less than pretty. My goal is to keep the wiring as hidden as possible -- or, at least neatly concentrated.
I've also removed the MSD box from the firewall. Everything will be mounted under the dash. I made a plate from 1/8" aluminum. The MSD box, Megasquirt and Megsquirt Relay Board will mount to this plate. I tapped the holes in the plate and then cut the screws flush on the bottom. Then the plate is bolted to the top of the glove box. With the dash pad installed, you won't see anything.
Finally, I picked up a fuel tank sump kit from Competition Engineering. It should solve my fuel-starvation issues. I'm just worried that I'm not going to like the look of the car from the rear with this installed. Now I need to actually remove the tank from the car and find a place that is willing to weld the sump in.
That's enough for now...
[/img]
