MKII GTI VR6
Thanks guys! I was going to wait until winter on the interior but I've already started. The rear carpeting with some cleaning is surprisingly near nint. The rear side panel "cards" also cleaned up great with a little heat gun action and some new contact cement. The interior without some finish uis just a little to "rustic" for me to handle. New front carpeting is on the to do list.
Pull- a- part again yielded great results 2 frt. wiper arms w/ blades $ 7 bucks and they are brand new OE VW, taboot- seriously- I didn't even have to clean them up, not even a wipe down. I was so impressed I called Classic VW and they told me they would be happy to order new ones for me @ $45.00 each - blades not included.. Nice ..best find yet, fom there. Also got A pillar trim, rear view mirror, interior door levers, window cranks, and some sweet boxing gloves!! - pics to follow of those babies.
And heres the clutch bleeding tool I made -
The inspiration for this tool can be seen here: http://www.youtube.com/watch?v=wdf--suwqw0
I'll let you guys know how it works
I'm starting to run out of stuff to do!! Got all the rear carpeting in and panels, shock tower brace and finalised all the hatch wiring. Window tint was removed from driver and passenger windows (it was in bad shape). Ecu mounted properly in rain tray and a bunch of little odds and ends. Still have to beed the brakes and clutch and flush the cooling system I'll get to that soon.
I've been told that the sunroof can be difficult to install and adjust on these older VW's. Not at all! I installed a new seal to replace the 20 yr old one and it went in so easy.
A few weeks back I met up for Sunday breakfast with some fellow Tiresmokers.....I drove my VR. After the breakfast and a litlle show and tell in the parking lot, I left w/ Tiresmoker was behind me on his SV. We turned off of
306 on to another road and from that 2nd gear turn I nailed it and started shifting. I knew that 'smoker was reading my mind and he followed. The road was clear and I gave it all it had up until about 3000 in 4th. Not to shabby, I thought. I was pleasantly surprised to find out that the SV Was not really pulling on me.Huh
. Later 'smoker and I went on a backroad cruise - no speed, just a shake down cruise. I learned a few things.
- Ohio backroads are rough, particularly for a lowered MKII with a VR powerplant in it. A small scrape was heard/felt. The engine oil pan sits real close to the ground, same as the CAT. Must drive speed limit on bumpy roads. Also make a skid plate for the engine (blueprints for it are online).
- I hate the MOMO steering wheel. To be replaced with a O.E. VW wheel.
- Slave cylinder and Clutch Master cylinder are Almost shot. At least I know there easy to bleed.
- Brake master Cylinder is from the 16V chassis. This is not nearly large enough for the Corrado Brakes. To much peddle effort. Will be upgrading to one from a MKIII or A late model Audi. This is normal. I just wasn't sure what it had in it.
- Torque is great I'm so used to My 1.8 8V driver that the amount of V6 grunt is so nice! :
- The handling is pretty good. I wasn't "pushing " though. The combination of The shocks, springs, strut tower brace, tires and wider track suspension all really add up. Theres a track day in my future. To try pushing it on the road would be irresponsible. It sticks that well.
- All fuel pumps die eventually. The one thing I didn't replace in the fuel system had only those 40 miles left in it. It died on Sherman Rd. Luckily this is only a few miles from home. So... out came a Chevy to the rescue. Hmmm. a V8 powered VW
Yes there is video of that!!
I would like to thank the Rookie for his call back and offer of help ( I broke down in his neighborhood).
Seems like a lightly traveled cloverleaf style freeway entrance or exit might give you a fix before you go to the track. Maybe 10 PM or other non rush hour time.VeeDub wrote:To try pushing it on the road would be irresponsible. It sticks that well.
You going to autocross it?
Probably...the problem with autocrossing...IMO - its like a table dance...just enough to get the blood flowing, but not enough to get the job done. I have autocrossed and its O.K. Theres to much down time compared to seat time. Doing a track day really spoils one. Its hard to beat Nelson ledges when comparing entry fees to auto cross prices http://www.nelsonledges.com/GOTfunDays.aspx Autocross runs are to short, time wise. A track day lets you get to know your car, the track, your abilities at the limit and most importantly you are learning in a "safe" environment.You going to autocross it?
Re: 89 GTI VR6
Its been a while since I worked on it but i've been busy. With our 1990 GTI going to the junkyard ( http://tiresmoke.org/viewtopic.php?f=3&t=954 ) I now have all the little odds and ends (nicer seats, carpet, door cards, hardware - yaddi yadda....) that have been hard to to find.
Some POR-15 Before the carpet goes in.
Drove it over to Tiresmokers w/the interior "roughly" installed.
I hope to get back on it this week. My daily driver (91 GTI 8valve..... I know I'm asking for it...) needed to have this installed
My first time installing a car head. It runs good. Powerline in Mentor, Ohio did the valves, stem seals and guides. Also Tiresmoker came over and gave me some help on the ignition timing to get it started.
Re: 89 GTI VR6
we need to keep you informed when we are going to Fun Days at Nelson Ledges.
Re: 89 GTI VR6
Yes please do, even if I dont run the VR. I am going to the 24HR though.MostMint wrote:we need to keep you informed when we are going to Fun Days at Nelson Ledges.
I did make a GREAT Pull-a-Part score from the Akron location yesterday. They actually had a '92 Corrado VR there. Ive been looking for some hard to find parts for years. Despite the thunderstorm that I worked in (my wallet and shoes are still wet
Re: 89 GTI VR6
Will this precision machine and you be available on Friday July 22? A guy I work with is having a track day at Nelson like no other on that day.
Re: 89 GTI VR6
I'm starting to get the finished interior back together. I had it roughly installed just to drive it for some shake down runs to see if everything seemed fine with the mechanicals of the driveline conversion. This also served the purpose of giving me the motivational boost to get going on the interior.
If I was just installing the "stock" dash this would go alot quicker. Instead I'm going with the Corrado SLC dash board (definately lacking any STOCKNESS
) This will allow for the use of the Corrado VR6 gauge cluster so I'll have functional gauges, the MFA features and the nicer looking dash.
This is fairly involved as nothing fits with the Golf GTI body. Things to modify:
1. Remove 7/8" from the leading edge of the Corrado dash using poster board template made from a GTI dash.
2. Relocate Corrado dash cowl mounts to match body.
3. Weld on extension tabs to body- to match cut down dashboard.
4. Remove Golf body steering column mounts as this will interfere with the VR gauge cluster.
5. Fabricate column mount for the Corrado column.
6. Shorten Corrado knee bar by 1"
7. Fabricate and modify knee bar to body mounts.
8. Raise HVAC plenum(s) to match the new dash.
9. "Massage" HVAC duct work with a heat gun to match dash vents.
It might sound like PITA but its really not that bad and the final result I've seen on other peoples cars looks great.
Heres the column mount and knee bar I fabbed
Custom wrench to tighten column to body! Knee bar cut and ready to weld
I'll get up more pictures later. I would also like to thank Ken for the use of his welder. The dash conversion is basically impossible without cutting and welding.
Re: 89 GTI VR6
There is another track day coming up in Sept or Oct. Just sayin.
