chevelle summer project(s)
Driveway signin'?
Hey, I like this driveway signin' thing. Too bad my pen is so far away. I think 'Ol Blue and I could lay down quite a signature. Heck, New Blue might be able to put down an initial or two. Hmmm...maybe four??? I'd be sure to break somethin' if I try in 4wd (unless you have a dirt driveway).
Mark,
I appreciate the trailer offer (and don't think I didn't consider it first!), however, I just think a tow dolly would be a lot less effort, since it won't be moving under it's own power, unless you have a winch to pull it up on the trailer.
As for signing the driveway -- let's keep it in the street for now.. My driveway is nice concrete -- and lots of it.
I'm heading out to the house now -- I'll shoot some pictures and post them.
Well, I made some progress today -- the engine is back out of the car to investigate the oil pressure problem. I bought a new engine hoist, the kind that folds up. It was at this twice-yearly sale by homerion or something. It's all chinese junk, but for $129 I got a hoist plus engine tilter thing. I also bought the dual-halogen light in the background for $20, and also hung a new 4-tube light fixture in the garage, giving me a lot more light.
Oh yeah, the water has been completely drained.
Fresh Engine
$129 is a deal.
I remember paying $180 something for mine, back in the 80s. Mine is 'Harbor Freight' quality, i.e., it's imported too. The only thing that can go bad, is the cylinder. Mine came with an extra set of seals.... like I'm ever gona replace just the seals....
The tilter thigine is neat. Especially helpful when installing the engine and trans together.
Looks like we'll both be high 12s for '08.
2015 Yamaha FRJ
2015 Yamaha FRJ
Well, I tore into the engine today. I removed the oil pan and rear main cap and verified that the oil plug was in place. Next, I removed the timing cover and found that I had not installed the 3 plugs on the main oil galley. doh. Took off the cam gear, found the plugs from the machine shop and installed them. This easily explains my oil pressure problem.
I'll hopefully get the engine buttoned up before the weekend is over. Could I have it running by Christmas? on EFI? Starting to feel a little optimistic for the first time in a long time.
It was another productive day in the garage. I got some shelving hung up, I hung my pegboard behind the workbench, I wired up my garage stereo, hung up my trouble light and some misc re-arranging. The bottom shelf is perfect height to stand and use the laptop (which is where I'm posting this from)
I made progress on the engine today. The missing plugs have been installed and I have just about everything re-assembled except for the oil pan and balancer. I thought I had the correct oil pan gaskets, but I don't. And I need to get a harmonic-balancer-installer tool from Autozone. After that, it's ready to go back in the car.
oil pressure!
I got it back together today. I picked up an oil pressure gauge and hooked it up on the engine stand. 30-35 psi. That's much better. I also have oil to all 16 rockers. woo hoo!
1/8 npt
Woo-hoo on the oil psi find.
The garage looks great! Gota have tunes.
BTW, I still hold the record for 406 re-assemblies, at 3x.
Something I'm not proud of
, but none the less, I have the record!
2015 Yamaha FRJ
2015 Yamaha FRJ
Concerning the 406 re-build RECORD
If at first you don't suceed, try, try again. Maybe not specifically on a 406 Small block,
but as for doing the same thing multiple times, been there, done that.
I appreciate what you guys are going through. However, it seems the more you
have to do it over the better it feels when you get it right.
Unfortunately, I'm not out of the woods just yet. I seem to have some stripped threads in my crankshaft for the bolt that holds the balancer on. I can't get it tight enough to even come close to spinning the engine over. I grabbed my tap & die set and ran a thread cleaner in the crank and over the crank bolt. I even grabbed the other crank bolt from my spare 400 crank. thinking that the bolt I had just had worn threads.
I'm not worried about the balancer coming off, as the press-fit is pretty tight, I'm just worried about being able to spin the motor over by hand.
