This car has working A/C, climate control, sunroof, leather, etc. The interior is nice. The exterior needs only to have the front bumper painted, and there is a small patch of rust in front of the driver's rear wheel (only surface). The brakes are all like new, but have a modulation problem (someone blamed on cheap pads). I thought it was a master cylinder, replaced it, but didn't fix the problem. I've bled and checked all slides, etc, to no avail. I'm getting used to it though, so I probably won't do anything about it.
The car already had a K&N drop in filter, so someone has taken decent care of it. I did have to put a DPFE sensor on it a couple weeks after I got it to cure a new check engine light, but otherwise the car has been good.
It's giving me a consistent 23mpg, which is more than reasonable.
I'm working on getting a price on a posi unit installed to help winter traction, and maybe change the gear from 3.08 to 3.27 at the same time.
Anyway here's some current shots:
-bp
