My SD Garage
AKROVER
My SD Garage
Post by AKROVER »
I probably should have started a thread for my garage(s) when I bought the place. Our work and storage locations are almost as important as our cars. My main garage is a really nice size, 24X24. This provides plenty of room in front, behind, alongside, and between two cars to do just about any type of work. This is what my garage looked like when we first moved in:
This is what it looks like today, after my latest upgrade, new flooring.
The flooring is from Swisstrax, the premier supplier of snap-together plastic garage flooring. I designed the color scheme, working within their limited set of colors. I wanted to delineate the parking spaces from the work area and I figured it wouldn't hurt in getting the boss' approval if I made the entire thing Ohio State themed (she graduated from OSU and has forced me to watch college football for decades). The two big Os work for my purposes, but I knew I had enough red, black, and silver to change up the pattern if they lose to Michigan again. The tiles are easy to pull up and rearrange and I have always liked how red pops against black and gray.
I have been frustrated with the floor in my garage. It has a few minor cracks and lots of stains, but the worst part is that anytime I kneel down, I get dusted. When I work on the floor, my navy coveralls turn gray thanks to the dust that never goes away, no matter how much I clean. I also had several carpet runners in front of the work benches because standing on the concrete can be brutal. While the Swisstrax isn't exactly an anti-fatigue mat, it is much more comfortable under my old feet. Those carpet runners also got in the way of rolling the toolbox, the jack, or my creeper. The dirt from the concrete floor also seemed to make the wheels gritty. Now everything rolls smooth.
Swisstrax Pro tiles, and many competitive products, have an open mesh. Liquids will drain through the tiles and there are channels underneath that allow the liquids to flow to whatever drainage exists. This means that pulling a snow covered car into the garage won't result in puddles. The puddles will still be there, but they will be under the floor. In my climate, things tend to dry pretty quickly, and my floor mostly leans toward the garage doors, but the floor often remains damp to the touch in the winter and spring as the slab gets cold enough to inhibit evaporation. This should make spring work a lot nicer. The other advantage of that open mesh is that automotive fluid spills don't require immediate cleanup. When I did the brake work on the Jaguar, I had a few big spills which slowly spread out on the floor space that I was trying to work from (nothing like brake fluid in your hair). Now cleanup can happen afterword, although it will require pulling up some tiles to get at the spill. The tiles are remarkably chemical and stain resistant.
The dirt and dust also drops through that open mesh. The standard Swisstrax product has no flat surfaces so the dust really does settle below the floor, keeping the surface relatively clean and only necessitating an occasional removal of the floor for a more thorough cleaning. I bought the smooth version of their tiles because things do roll better, it is a lot more comfortable to kneel on (or walk barefoot), but also because it is a lower profile tile and my man door was going to require significant adjustment to fit over the taller tiles. That smoother surface will hold some dirt, particularly footprints, but it can be easily cleaned with a rag or mop. I spent all day walking around on the floor as I installed it and the dusty footprints were really minor, only visible on the black tiles.
The tiles can easily support a lot of weight, but concentrated loads like jack stands and jacks with small wheels can deform the tiles. My jack has very large wheels so it won't likely damage the tiles, but I think I will buy some sheet metal to further distribute the load of the jack and my jack stands. There are jack stands with wide flat bases and those will have no impact on the tiles, but my existing set has the typical sharp-edged base that can cut into the tiles.
Installation was reasonably quick and easy. The floor really is just floating there and cutting tiles to finish to the edges should not be done with great precision as the tiles will expand with temperature. I was surprised at how square my garage is. The two sidewalls were almost perfectly parallel, but the back wall did have about 3/4" of angle over the 24 feet. I had most of the floor down before lunch, but cutting in the edges took a bit more time. I made a couple of strategic errors, but luckily I bought a few spare tiles.
This is an indulgent upgrade. It wasn't cheap, but I am not getting younger and having a nice work area matters to me. I did get a decent discount. If you use their design tool and then request a quote, they will give you a discount. They were also running a 10% off sale so the discount was on top of that. This stuff retails for about $5 per square foot, but I got it for about $4. So, happy birthday to me.
Re: My SD Garage
Were you paid to do this ad for Swisstrax? You should be writing an infomercial for them. :lol:
Looks real nice in there. Big transformation for sure.
Re: My SD Garage
When my detached garage was put up they sprayed the concrete with clear which seemed like a great idea until the first time gas spilled and ate through it. I’m sure some of it still has the clear.
It’ll be interesting to see how your experience with jacks and jackstands go - that would probably have stopped me from trying this approach. You could weld flat plates to the bottom of the stands which might simplify protecting the floor when using those.
I do like a cleaner floor. I’ve debated getting a Roomba for the garage.
Looks good - keep us posted on real life experience as you go.
AKROVER
Re: My SD Garage
Post by AKROVER »
Basement Paul wrote: Sun Feb 01, 2026 9:45 am Were you paid to do this ad for Swisstrax?
Yeah, they should pay me, but I was just documenting the reasons I bought into this significantly different and expensive flooring paradigm. As MostMint requested, I will be updating the good and bad. It will be interesting to see what I think in a few years.
I did a small project out there today and noticed a couple things. The floor does make some noise when walking on it. It isn't that my footsteps are louder, likely quieter with less echo, but the tiles make a sound against the concrete as weight moves around. The floor is more comfortable to stand on than hard concrete, although not exactly soft. The floor is also easier to clean with my shop vac. The wider floor cleaning attachment that I have tends to suction itself to the concrete if I don't hold it at the perfect angle. With a mesh floor, there is always air flowing. The sawdust that I generated today cleaned up easily, including the visible stuff within the mesh of the tiles.
AKROVER
Re: My SD Garage
Post by AKROVER »
Yesterday, I put handles on the cabinets in the garage. When we moved in, some of these cheap old kitchen cabinets were mounted on the walls of the garage and some were mounted in the basement. I decided to move them all to the garage. I rolled gray paint on the cabinets and sprayed red on the doors to cover up the hideous dark fake woodgrain. The paint has held up nicely for two years now, but every time I reached for a door with greasy hands, I realized I should put some handles on them. I finally remembered to order some cheap Amazon Basics handles in black, a simple upgrade.
Re: My SD Garage
From ten feet, those cabinets look high end. You effort has paid off.
AKROVER
Re: My SD Garage
Post by AKROVER »
Today's project was installing some brackets for hanging my Craftsman power tools and batteries under the cabinets. This frees up a lot of cabinet space and a little bit of drawer space, which should help me get better organized. I also mounted my battery chargers on the side of the cabinets which gets them off a shelf. The tool hangers only work for some of my tools, but these are my most used tools. The more awkward shaped tools are still in the cabinets or on the shelves like the reciprocating and circular saws.
Batteries under and battery chargers on the side (upper orange charger is for my Echo mower/string trimmer/chainsaw)
Tools hanging under cabinet
AKROVER
Re: My SD Garage
Post by AKROVER »
I don't seem to be very good at pulling cars into the garage to a reasonable and consistent depth. I always seem to have too much room behind the cars and they intrude unnecessarily into my work area. My new floor delineates the parking area from the work area, but I can't see that from the driver's seat. With the VW, we figured out that shifting into reverse while coasting forward brings up the rear camera which then stays on for a few seconds after going back to first gear. It was easy to drive to the same depth as lines on the camera lined up with the end of the garage floor, but that put the car slightly deeper than I really want. With a new longer car soon to replace the VW where activating the rear camera would require coming to a dead stop first, I thought I'd better figure out a better way of pulling in, particularly for my wife. Somehow, the thought of convex mirrors occurred to me. Amazon had a set of two 12" mirrors for $20 that includes flexible arm mounting hardware that makes them very easy to adjust. When they arrived and I looked at installation, I immediately realized that my cabinets provided the perfect mounting positions for both of them.
Jaguar parking mirror is on cabinet on left wall showing a view of fronts of vehicles. The other one is on top of the cabinets on the back wall aimed downward to show front of vehicle position. The Jag is parked exactly where I want it, and the VW is in too far in these pictures.
Re: My SD Garage
In the attached garage I have old plastic key fobs on a string from the ceiling. In the detached I have figure out to align the side mirror with something along the wall. Thumbs up on the mirror option.
