Both at work and at home I have to log in twice. After the first login it shows I am logged in at the bottom, but at the top it still gives me the option to log in.
Anyone else having this problem?
I used to have the same problem with someone else's phpBB, but I've never had this problem here. The phpBB support forum is down at the moment. I'll try again tonight.
OK I was about to retract the "no email notification comment", since I found a recent email in my "bulk folder" on yahoo. But as of now I did not get email notification on wxo's post to this thread.
I double-checked your profile settings and you should indeed be getting the emails. Since you found one in your bulk mail, I would double-check your spam filtering on your email. If AOL has "white-listing" for email, I would add *@tiresmoke.org to it.
Try logging out of Tiresmoke.org, then logging back in. I changed the cookie settings per this post, we'll see if it works. I don't have the problem here, so it's hard for me to test, but I've experienced it on other webboards that use phpBB.
