I got some progress under my belt here the past couple days. Starting with a cardboard template, I made a mounting plate from some aluminum (courtesy CutNPaste). I mounted the MS3X on some MSD rubber isolation mounts. I got fancy with the fuse panel and relays, using rivet nuts to mount them. No self-tappers here.
MS3X has two main connectors, the main MS and the 3X. I went through each and pulled aside / bundled the wires that won't be needed in this installation. I'll prob leave 24" of anything I don't use, just in case some unknown future case. Properly taped/secured. The bundled stuff you in the pics will all go away. The two bundles going out the firewall get loomed and secured.
I was able to reuse the factory firewall grommet, which is a really nice piece.
This car has (I think) a on/off switch for TPS. There is also no idle-air (IAC) valve. That's gonna be a little bit of a challenge.
Wires not used & trimmed on MS connector:
Green Outputs: INJ1/2 (batch fire)
Blue Outputs: INJ1/2 (batch fire)
Tan: CAN-L, CAN-H, SPR3, SPR4
Brown Output: SpkA
Wires used on 3X:
INJ A/B/C/D
SPK A/B/C/D
Green input: Cam signal
Green output: Tach out
Green output: PWM Idle (for Fan relay control) ** (there is also a "PWM idle" pin on the MS harness, they are two different outputs)
Blue Input: Ext_MAP (Map Sensor, prob GM)
Blue Input: SpareADC (for Coolant pressure sensor
Wires not used & trimmed on 3X connector:
INJ E/F/G/H
SPK E/F/G/H
Gray Inputs: Nitrous In, Datalog In, Launch In, Tableswitch In
Green Outputs: Nitrous 1, Nitrous 2, VVT, Boost Control
Blue Input: EGO2
Purple Output: Logic Output
Orange Input: Flex Fuel
Updated July 2024:
Crankshaft sensor:
Stock Porsche 3.0 S2 crank sensor, gapped at .9mm / .032"
Danst Engineering 36-1 crank trigger wheel and bracket. (not used)
On replacement pigtail, black = orig connector white, blue = original connector tan/brown
On replacement pigtail, black goes to MS VR+ (MS white) and and blue goes to VR- (MS black)
(see picture down thread)
Tooth #1 angle - 114 degrees (factory 60-2)
Tooth #1 angle ~ 230 degrees (36-1)
TPS Sensor:
1994 BMW 525 6cyl
Falk Engineering adapter for sensor
944 Throttle body rotates opposite BMW, so sensor is wired 'backwards'
*) black = +5V
*) orange = TPS signal
