What do you guys do with old 2-stroke fuel mix -- like 32:1 or 50:1 mix? My father has always just poured the remains, usually less than a gallon, into the tank of whatever car he's driving. The thought of this makes me cringe, but I've never seen any adverse effects to his car from this. Thoughts or comments?
disposing of old 2-stroke mix?
I can't see any bad effects from this espcecially if you put a quart or two of 32:1 in a full tank of gas. At that ratio it can't be much worse than an oil burning engine.
The only possible thing I could think of is if it would mess up the O2 sensor or the catalytic (assuming you have them). Maybe I would put it in the gas for the beater car or the lawnmower.
If you have a bunch of drain oil, you could mix it in with that. But if you put it in a car, it would be better to keep it out of OBDII stuff just because if it sets a code, you'll be looking at a light for a long time. '95 and older stuff might smoke a little, but mechanically won't hurt anything.
