chevelle summer project(s)
MostMint wrote:Glad to hear it's running. Should give you some motivation to keep going. Sounds like some starter project this weekend. Did the flexplate change? It could only be the bolt mounting holes or the flexplate that changed right?
The block (mounting holes) changed. Flexplate and starter have worked together before. I ordered the starter today, (SUM-820323) even though I may try my original one again, first.
Chree: glad to see you made it over here. I have a feeling that before I'm done, I'm going to end up using the 8-pin HEI, triggering the MSD via the white wire from the HEI's Coil-Negative terminal.
I got the new starter in last night. The engine now cranks over easily and it fired up easily too. It was after 11pm last night and with no throttle cable to the carb, I didn't run it very long -- maybe 2-3 minutes.
I finally have a little bit of video.
woo hoo.. sounding good so far!
SWEET...
Sounding mellow
Throaty little devil! :)
Sounds of success!! Great job, Dave.
Start Up
Yea baby....
Nice. :D
Sounds like crap.... Just kidding, the car sounds great! It definitely sounds different than it did before, in a good way.
Good work D.
