Rear axles installed, ebrakes assembled properly
Spent an hour with seam sealer to seal up the newly installed section.
Lost about a week with Cadillac project.
Reassembly to start next!
Big round of welding. Almost done. Missed a couple small welds, and still have to put the sheet metal on the bottom of the A-pillar in the door jambs.
Made contact with the junkyard in Dover - the dash is in - so I went to pick it up.Spent an hour with seam sealer to seal up the newly installed section.
Wow! Major visible progress! Can't wait to see more!
Video update #6: https://youtu.be/8V3NAxxBQRc
Installing things on the car:
• Transmission tunnel insulation and driver side heat shield
• E-brake pedal
• Interior firewall blanket
• Some wiring harnesses. Trying to figure out where the harnesses are supposed to route, and attach to the car presents some challenges
• Main under dash HVAC assembly. Some additional adjusting to firewall to get a good fit/seal
• Front struts and upper control arms. The LF upper control arm had damaged threads on the ball joint. I debated taking it back but it was faster just to fix it with a bit of grinding, filing and a die • Sheet metal for bottom of A pillar and part of frame rail fitted and clamped in place
• Brake pedal
• Gas pedal
• Hood hinges and hood latch cable
• Manual park release cable Started on the dash work
• Decided it will be easier to move the cover to my existing frame. The wiring harness on the junkyard dash had some after market mods, moving the harness looks quite involved since it winds all around the dash
• Removed the pad from the junkyard assembly
• Discovered this assembly has a passenger airbag and also a key fob. The first dash I ordered was not to come with the airbag. As it turns out this one was about $100 more and this explains why. Other
• Did some prep work for expanding foam – closing up some holes and labeling points to add the foam • When I went to install the brake booster I found it had a dent in the bottom from the crash. This explains the lack of brake assist when I was lot driving the car last year. I thought it might have been pinched brake lines.
• E-brake pedal
• Brake pedal
• Gas pedal
Dashboard
Turns out the original dash frame was bent and bolt holes did not line up. I was concerned for a bit but test fit of the replacement dash frame showed all the bolt holes line up. With this information I moved the original wiring harness to the new frame and reassembled the whole thing. To make sure I got everything connected in the right places, I removed the harness from the dash frame one or two connections at a time and installed the original right after.
After assembly and other prep I installed the dash. Install was pretty straightforward, and this job is so much easier with no windshield and no front seats. Lots of bolts and small screws to install, and wires to connect. I had labeled most of the connections which helped.
Other
Kurt did the final welding for the lower A pillar sheet metal panel. Cleaned up the welds and got some paint on them Obtained and installed the brake booster
Prime and paint the scratched areas in the windshield frame – before dash install to avoid spills/cleanup. Did brush touch on these since none of this will be visible
Got busy with expanding foam in the driver side frame rail and lower windshield brace – replacing what was removed during repairs. It took about a can’s worth
Remove deployed side curtain airbags and install replacements. This took longer than expected as I had to remove visors, hand grips and clothes hangers to move the headliner to access the bolts holding the airbags in. Also found a small rip in the headline presumably from the airbag deployment.
Install the front carpets – these loop in over the lower dash support brackets. Also put in the ducting that goes under the carpet to the back for the car
After the dash was installed, the steering column, glove box and gauge cluster were installed. There is a metal ring that holds the seal at the firewall, and of course it was bent. Each time I find another bent item I wonder if this is the last surprise from the crash. The brake booster had that title for about a week. Definitely into a new phase for this project - still a long way to go but expecting a lot more assembling and less fabricating from here on in. After looking at this shell for so long it's really nice to see it starting to come back together.
Also - now over 525 hrs I'm hoping less than 200 to go
Other
Installed engine on the subframe. The driver side mount was wobbly – I figured it had been damaged in the crash. Once I got the heat shield off I could see the top mount had loosened up. Easy fix.
Installed A/C line to the exchanger unit on the firewall. Tried the Challenger part but it was bent. There is an anchor on the LF shock tower and the mounting bracket was at least 3” away. Fortunately I saved this part from the Charger and they are the same part. Also installed heater core hoses and a few other odds and ends. Test fit the driver door. It was still a bit bent – the lower edge of the door was about ¾” too far out just before the B pillar. Took a bit to realize the top of the door was too far in. Fixed this by pushing in on the bottom of the door while pulling out on the top of the door. Also had to adjust the striker to get the door to close properly. I’m doing all of this without the outside skin on the door – looks good right now but won’t know until the door skin is on to know if it really does fit OK. Went to work on the left front fender. This was by far the most damaged panel. I was comparing it to the sample fender I had, but ultimately wanted to compare it to the passenger side front fender. It was pretty good from the last round, but there were still more adjustments to be made to get the alignment with the A pillar right. Took a few rounds of tweaking the fender shape by the A pillar, but also where the fender attaches to the car along the top of the fender. Once I had that side in order I went back to driver side. It’s hard to explain all the adjustments I made. There was a big adjustment to the top of the fender in the front – five hours of work so far. Still a ways to go but it is fitting to the car. Sent the seat belts out for rebuild. Upon their return I put them into the car, and reassembled the back half of the interior – seat belts, side panels, seats. Lots of visible progress for relatively little time on this front.
Ordered some suction cups to help with the glass installInstalled A/C line to the exchanger unit on the firewall. Tried the Challenger part but it was bent. There is an anchor on the LF shock tower and the mounting bracket was at least 3” away. Fortunately I saved this part from the Charger and they are the same part. Also installed heater core hoses and a few other odds and ends. Test fit the driver door. It was still a bit bent – the lower edge of the door was about ¾” too far out just before the B pillar. Took a bit to realize the top of the door was too far in. Fixed this by pushing in on the bottom of the door while pulling out on the top of the door. Also had to adjust the striker to get the door to close properly. I’m doing all of this without the outside skin on the door – looks good right now but won’t know until the door skin is on to know if it really does fit OK. Went to work on the left front fender. This was by far the most damaged panel. I was comparing it to the sample fender I had, but ultimately wanted to compare it to the passenger side front fender. It was pretty good from the last round, but there were still more adjustments to be made to get the alignment with the A pillar right. Took a few rounds of tweaking the fender shape by the A pillar, but also where the fender attaches to the car along the top of the fender. Once I had that side in order I went back to driver side. It’s hard to explain all the adjustments I made. There was a big adjustment to the top of the fender in the front – five hours of work so far. Still a ways to go but it is fitting to the car. Sent the seat belts out for rebuild. Upon their return I put them into the car, and reassembled the back half of the interior – seat belts, side panels, seats. Lots of visible progress for relatively little time on this front.
Video update #7: https://youtu.be/IHbLprmB5_I
liking the video, so far so good!
Installed the center console. The storage compartment had a strong smell (perfume?) so I ended up washing it out with soap and water before install.
Install the ABS module and brake lines. Used the Charger parts car brake lines as they were all straight and not broken.
Did some heavy lifting on the LF fender. It was by far the worst panel. It had been roughed in during earlier sessions but now it was time to fit the thing. The shape was off in multiple ways so it was quite a challenge to get it to align with the door, A-pillar and hood. Ultimately, I made some small adjustments to the bolt holes at the top of the fender so the fender would clear the door. After that I fabricated some patches with galvanized sheet metal to cover the holes from grinding on the barrier, and connected them with panel bonding adhesive.
Also did some work on the driver door. Aligning the structure with the rocker panel, front fender and rear ¼ panel. Test fit the window to make sure it aligned with the window seal on A pillar and roof. Then I made a patch to cover the hole in the door skin, and finally I reinstalled the door skin using panel bonding adhesive and peening all the edges of the door skin back over the frame. After all this I put the door back on the car, and installed the door handle, side mirror and the trim at the top of the door.
Started fitting the hood. The first step was to get it on the car. This showed there were multiple minor alignment issues. Move the hood around a bit to get the gaps looking decent to the fenders. Took the hood skin off and got to work getting the height of the edges of the hood structure aligning with the fenders. The LF corner needed the most attention, with reshaping to get the corner down, and a patch to support a crack. Used a piece of steel and rivets on it. It’s better but not done yet.
Test fit the windshield to confirm there were no changes in the window frame from the welding process. Touch up the window frame with orange in a couple spots where my unmatched touch up was above the seal in the test fit.
Installed the front bumper and side brackets. Installed the plastic bumper support as well. One of the side brackets was a perfect fit and the other one was off a little – but easily straightened. This allowed me to set the front bumper cover on the car. This uncovered some misalignment where the RF aligns with the bumper cover – I took some swings at it and its better but not there yet.
