1990 Corvette Z51
Re: 1990 Corvette Z51
If I can do it in my S10 on the A/C side, we can get it done on that thing. If you want my skinny hands to help, give me a holler and we'll get it done.
Dang, has it really been that long since I worked on this thing??
I decided to try tackling the headlights today. I watched the ChrisFix video on youtube, https://www.youtube.com/watch?v=sPj1kJm4AnU
I had already purchased a kit from Amazon with the brass gear and nylon bushings. I started with the drivers side. I got everything taken apart pretty easily. You need a couple T30 torx, a 10mm and a 1/4". When I got everything apart and removed the cover, I was surprised at how clean it was. The gear itself was fine. But the nylon bushings were all crumbled.
I got it put back together without too much drama -- I thought "why did I wait this long to try this??" But, when I did my test, I get nothing. The light turns on, but no action from the motor. The un-touched passenger side one half-flips. I know there is a 2-wire connector for it, and its connected. I didnt try anything before I took it apart, so I dont remember how well it worked/didnt work. More to come..
the first thing I would do is find the ground wire connection and clean it. there is some notoriety with bad grounds on C4s
you can also turn it by hand to raise the light to make sure nothing in the mechanism is bound up
C4. C5. Whatever it takes!
A little progress tonight. I applied 12v directly to the headlight motor, and it works. And it moves exactly like it should.
So I guess there is a headlight actuator relay thing mounted right in front of the left front wheel. It sends the power to both sides individually. Might have to replace that.
I removed the passenger side headlight assembly and got the gear replaced in there too. Like the drivers side, the gear was good, but the bushings were ground to dust. However, the rollpin split in pieces and I dont know if I have another one. But I'm on the re-assembly phase, so I should have working headlights very soon.
Feels good to make some progress on this car.
I finished the passenger side headlight today and got it back in the car. It works good now. I have the headlight actuator on order from ebay. I was hoping it would be here this weekend. Once that is in, the headlights should be 100%.
I got the headlight actuator relay and installed it. With the hood up, both lights work as expected, yay! But when I closed the hood, now the passenger side is hitting something and not able to fully open. Hopefully just an easy adjustment, but it seems odd.
Next up are the header gaskets. Passenger side is blown out bad. That's the main reason I haven't been driving it. Of course, it's the harder side to do, but I'll just do both of them. I'm thinking about sending the headers out to have them ceramic coated. Even with what looks to be angle-plug heads, the spark plug boot is just too close.
I've had trouble with the radiator overflow hose obstructing the passenger side headlight. from the factory there are several loops to hold it in place but if any have been removed the hose can shift.
I finally made some progress on my Vette. I got the passenger side header gasket swapped out. I can't get to the rear bolt on the #8 exhaust port, so I'll have to try from underneath.
I bought new Stage 8 fasteners for the headers. They have a little 3/16 hex socket in the middle of the bolt which was very handy for getting them tightened. I still have to put the locking pieces on.
I made up a new set of plug wires since I saw the old ones arcing to the headers. They didn't look awful visually, though. I bought a set of Pertronix Ceramic boot plugs. As the name says, they have a ceramic boot at the plug wire end. That should make them pretty heat resistant.
The thing that has given me the most grief is the belt tensioner. It has a 1/2 square female opening for a tool, but when the belt is tight, that opening is right in front of the cross bar. So now, I have the belt on successfully, but my tool is stuck in there. Aggravating. I'll have to take the belt off, let the tensioner move to where I can get the tool out and modify it.
No good pics to add...
It's not done-done. I still cant get the rear most header bolt in, even on the lift. I think the gasket might be slightly intruding on the hole. But I took it for a short test drive last night anyway! I put in 5 gallons of gas and went to the grocery store. It sounds good, it runs good. I only really laid into it once, and no mis-fires -- all good!
The headlights pop right up.
The brakes still kinda work / kinda suck.
But it was nice to drive it for the first time in forever!
This is one of the ceramic boot plug wires. I think I'm going to like these.
I put my new license plate sticker on and drove it into town to pick up dinner tonight. It's running well, headlights work good, both low/high beam. I'm pretty happy at the moment.
So I'm really happy to report that I've been driving this car a bunch and its been running pretty good. Its the car in the garage I can drive on just about any day. I drove it to Tony's office on Wed night for dinner with him and Paul, and work on Thursday.
