This engine is presenting a few puzzles. Think two more are sorted out.
With the serpentine belt, some Ford water pumps are driven in reverse rotation by the smooth side of the belt. Its obviously important to get matching pump and timing cover. Thought it would be simple to look up a waterpump for the '95 F150 5.8L engine and get the right one. Nope. Parts sellers list both standard rotation and reverse rotation for that application.
The water pump pulley would indicate which pump (ridged pulley for standard rotation; smooth pulley for reverse rotation) IF I HAD ONE. The fan and water pump pulley were broken off in the wreck and not with the truck.
A serpentine belt diagram for that truck would tell me but couldn't find one online.
Posted a question on http://www.sbftech.com and got the answer. Reverse rotation. Pump and timing cover are on the way from Summit. Now to find a reasonably priced pulley.
Second puzzle: how to eliminate the air pump. Delete kits are available but kinda pricy at around $70. Found online posts where guys have just removed the air pump and run a shorter (91.5") belt. Shorter belt is on the way from Summit. Sounds like the 91.5" belt may let the tensioner extend too far and not put enough tension on the belt. If it seems too loose the alternator will get some spacers to tighten it up.
Another thing to thing about -- the throttle lever. Since the truck had a 6 cyl in it, the throttle lever on the firewall extends over to the right side of the engine while the V8 pulls the throttle open from the left side. Modify the existing throttle lever? Find a throttle lever from a V8 truck? Use a Lokar cable? No hurry on that one.
Called Prestige Motorsports AGAIN today. They planned on finishing assembling the heads today but their power is out. (It really is.) Said the heads would be ready on Friday. We'll see ... I'm ready for those parts. Been trying to get a top end kit since early August. Shouldn't be this hard.
