iRacing broadcasts
Re: iRacing broadcasts
CCiS VIR race report
Started P24 of 43 cars, ended P28. Got roughed up the first few laps, lost another 5 seconds slowing to avoid a wreck on lap 15. Ended up 93 seconds behind the leaders, and if you subtract out the 20 seconds or so lost due to incidents I would have been on par with other races I've done this season.
Up next: CCiS at Mid Ohio
race day: 8/27 coverage starts at 9:20 PM
https://www.youtube.com/watch?v=ubu8r9zgfy8
Up next: race 1 XSLR season 10 tonight
https://www.youtube.com/watch?v=p066B0-IL-U
Broadcast should start sometime around 8:10 pm
Up next race 2 XSLR season 10: ARCA cars at Las Vegas Motor Speedway on 9/14 at about 8:10 PM
https://www.youtube.com/live/N_BRQRm3Nb4
Race 1 I qualified P3 of 14 and hung with the lead pack til about lap 20 where they were two wide exiting T4 and I didn't judge exit speed right and tagged the outside wall - this messed up toe in and I was about 1 second a lap slower after that. Race ran green for all 85 laps and I was not able to recover. Ended up P11. I may have been a bit tired from being at Mid Ohio all weekend for the ChampCar endurance race.
Up next: CCiS racing GR86 at Brands Hatch.
Wed 9/17 9:20 PM broadcast. link here https://www.youtube.com/watch?v=I_EqF0XXFRU
XSLR Season 10 race 2 report - LVMS:
I knew that full speed fuel consumption and staying green would require 2 stops. So I started saving right at the start. All was going to plan until lap 74 when the guy to my right bounced off the wall in the tri oval and ran into me. Sadly this did not bring out a yellow and I finished two laps down. These paved ovals are not my strong suit so it was quite disappointing that a solid podium chance was wrecked by someone being careless. I'm a bit cursed on these tracks as this was literally the only car contact that caused damage the whole race.
up next:
Racing ARCA cars at Bristol with XSLR coverage starts tonight at 8:15 PM https://www.youtube.com/live/hMgRsWtXTIk
CCiS GR86 at Brands Hatch race report:
Tried pitting coming to green and for the first time I got a 40 second hold for entering closed pits. Then I had contact with a wall and had to come in for a fast repair about 2/3 into the race. This turned a P15 start into P21 finish. Had some really good racing in the last 15 minutes or so - traded positions with a guy several times in the final laps. He passed me on second last lap but then made a small mistake on the last lap and I retook the spot.
XSLR ARCA at Bristol race report:
Once again I qualified near the front in P3. I expected this race to be about tire saving. Running flat out is harrowing as you have to carry a lot of speed on exit of T2 and T4 which ends up in wall contact if not done right. However with the tire saving that was a lot less risky so the drive was good. With 12 cars in the field and a 1/2 mile, there was bound to be a bit more traffic than normal, and with the tire drop off anyone coming out of the pits on fresh tires will be faster than you which also added to the traffic. I started in tire saving mode right away. After a short time I found myself following Jake the points leader and master of ovals, while a few guys ran up ahead. I figured I was doing exactly the right thing, however about 1/4-1/3 the way in Jake just started going a little faster while my tires were telling me I had to go a bit slower. A few guys that were showing more pace in race had issues and I was able to finish P4, for my first good finish of the season, and first good finish of the last two seasons on paved ovals.
We ran 165 laps at Bristol caution free. I ended up 4 laps down but only about 5 seconds behind the leader so really about 50 seconds back, which is not too bad.
Up next:
9/28 XSLR ARCA at Talladega: https://www.youtube.com/live/5xOTgtry_gc
10/5 XSLR Big Block Modifieds at Eldora: https://www.youtube.com/live/fTCUcVNFfGc
Up next:
10/12 XSLR big block modifieds at USA International at 8:10 PM: https://www.youtube.com/watch?v=unRY-DTnkZQ
I watched you get crashed out. That was dumb.
Tonight is the finale of 2025 ChampCar iRacing season - starts at 9:20 PM: https://www.youtube.com/watch?v=ZWpANDqWUYw
We will be running the BMW M2 at Road America.
Sunday 10/26 8:10 PM gonna try again with the dirt big block modifieds at Lanier
https://www.youtube.com/watch?v=a7zPLBogMM8
These things are a challenge to drive. With just under 900 hp, coming in over 2500 lbs, and with a rear axle that moves under power to turn, got to make the turn in early and under power, then try to steer with the throttle. I might have them figured out by the time this part of the season is over.
Lanier is located right across the street from Road Atlanta but it no longer operates as a dirt oval. Its not a bad track.
At Lanier I had a legit shot at the podium until 3 to go and I pushed it too hard on corner exit. I saved the car but lost three positions.
Catching up:
Last Saturday 11/1 I did a 3 hr enduro At Daytona road course with Gt4 cars with ChampCar. I split drive duty with my friend Aaron: https://www.youtube.com/live/GtfXLrPwcA ... 2z84&t=623
Last Sunday 11/2 with XSLR we did the final dirt oval race for season 10 at Charlotte dirt oval: https://www.youtube.com/live/AqWWbWJqct ... Cgcu&t=116
Up next will be XSLR racing with the rally cars in the dirt road course portion of the season. We'll be at Daytona on the rallycross track there. Sunday 11/9 8:10 PM https://www.youtube.com/watch?v=g8hW210ZBmo
Catching up:
Race report for XSLR @ Daytona Rallycross:
Qualified 3rd, lost that advantage in my heat race when netcode decided my car made contact and pushed me out of shape lap 1 turn 1. After that in the consolation race and the main I ended up with someone spun out directly in front of me on the first turn before the first lap started. Both times had to back up to get around the car. Finished 6th.
Next race is with ChampCar iRacing on Saturday 11/15 starting at 11:45 AM. Its a 3 hr enduro at VIR with GT4 cars.
https://www.youtube.com/watch?v=B8WQ7rf42MQ
Up next on Sunday 11/23 at 8:10 PM is rallycross at Sonoma with XSLR: https://www.youtube.com/watch?v=3i45f7FV5a4
VIR last weekend ended up with 17 cars and a track that was wet, then dry, then really wet. My co-driver was in the wet at the end and wrecked the car twice which cost us some spots. We qualified P15 and ended up P14. Hard to tell for sure but pretty sure we were P10 if we don't wreck.
I ran a race on 11/29 with CCiS: https://www.youtube.com/watch?v=r86pfis5Mfc
Not much to watch here since its a team event and my teammate was sick and unable to drive. However by running more than half the laps I was able to improve our points by 1 to 13 (vs 14 that we got at VIR).
I ran a race on 11/30 with XSLR: https://www.youtube.com/watch?v=6oPDl7sC-hA
<SPOILER ALERT>
In the feature I started in the back row, came to a complete stop before T1 since there was a big wreck and the track was blocked. Still someone flew backwards out of the wreck and hit my car, and mysteriously iRacing gave me a black flag at the same time. Still managed to finish P4 out of 13, though the time added due to black flag moved me to P7, and the two penalties I was given from the B-main took all my points.
I've run 11 races of XSLR in season 10 and been caught up in somebody else's garbage 6 times. Also the short format races promote chaos which I don't enjoy. It's time to start looking for someplace else to race.
Up next on Saturday 12/13 at noon is the enduro finale for 2025 with CCiS. https://www.youtube.com/watch?v=EcJy9vgRApE
<SPOILER ALERT>
The ChampCar iRacing enduro featured 12 cars, and due to one disqualification we ended up P9 - too many mistakes cost us time and we had to use both fast repairs.
Last Sunday I raced again with XSLR on the rallycross track at Road Atlanta and not surprisingly I got wrecked again in T1 lap 1, though I managed a P8. This make 7 of the 12 races so far this season I've been caught up in someone else's mistakes.
Today XSLR is switching gears and we are running the touring cars at VIR - coverage starts 8:10 PM https://www.youtube.com/live/Ucc5IUwtZyA
