C6 Corvette
Re: C6 Corvette
Well..... Its now Dec 2025 and she's in storage.
Off site, commercial 10x20 at $155/month. Purty much the going rate around here. No contract, month to month.
I filled the tank, pumped the tires up to 35psi, pulled the battery. It's at home, on a tender.
Interesting thing about pulling the battery. With no power, the doors can't open. (There is a mechanical release via the trunk thou)
Soo, as long as the hood doesn't latch, the battery re-install will be rather straight forward.
At time of storage, she showed 49,556 miles. About 8k racked up in 8+ months. :D :shock:
Dan and I have taken two trips in this. One to the Corvette Museum in Bowling Green KY.
Museum only, factory tours were not available at the time we went down.
I highly recommend this destination. We'll be back next year, with a factory tour.
She returned 30.1mpg! Also, was able to sit in rush hour traffic (Columbus) with the AC on and not get hot.
Hot idle, in gear, 32psi oil pressure and maxed out at 220deg. I will admit, when the rad fan is on, you can really hear it!
The other trip was to Love Canel NY. Sorta a spontaneous decision to head to NY. Buffalo traffic sucked!
Next summer, Dan and I are planning to take her to Virgina Beach for about a week.
I've spent about $2k in maintenance/repairs. The harmonic balancer, install labor and an alignment was the bigie at $1500
The HVAC control unit rebuild was $300.
'Stuck in park' issue. A common C6 problem. The 'park-brake' interlock fails, thus not allowing the shifter to be released from park.
I addressed this myself, took the solenoid activated locking pawl out of the equation, and replaced the cable bushings, a freebee from GMJohnny. Thank-you sir.
Two oil and filter changes
One trans fluid and filter change
One diff oil change (with the LSD additive)
Cabin air filter
One tire rotation (tires are asymmetrical, non-directional)
I brake inspection shows pads in good condition, and it appears to still have the original rotors.
I telltale sign being the 'speed nuts' holding the rotors on, are still there!
Existing belts and hoses appear in good condition.
The quarter mile event was a bit disappointing. 13.4 at 106. The Internet says the LS2/Auto should come in at 12.9, and 108mph.
A possible issue being the transmission. On both runs, she hit the rev limiter on the 2-3 shift. Hummmmm.
As a side note, all shifting is normal under street driving.
I've been watching You Tube vids on HP tuning the 6L80. It's really interesting all the possible variables and tables that are within the TCM .
I really doubt I'll venture into this, but it is interesting, and expensive.
And..... I've been pricing out new C8s. I know...... :roll:
Coupe, 2LT. With some mild options, the 'build and price' comes in around $85k MSRP.
I can only dream. :wink:
Re: C6 Corvette
So, I was guilted (thank-you Mr Smoker....) into getting the C6 out for the season.
Loaded up the Equinox with the battery, 10mm and 13mm sockets, and headed to my storage unit.
Pulled the car cover off, and loaded in the battery. 10mm for the terminals and 13mm for the hold down.
Positive first, and I expected a little spark as I did the negative connection, but nothing..... Hummmm
Anyway, not an issue because as soon as I opened the driver's door, the dash came to life.
Jumped in and hit the starter, and she fired right up as if I drove it yesterday. :D :D :D Last ran, around Thanksgiving.
Tire psi was all at 32-33. All gages read within their established normal range
Left the storage unit at 1pm ish, with 49149 on the odo.
Returned at 8:30pm with 49326. 177miles the first day out!
Twinsburg to Mentor (via River Rd ,one of my favorite routs, Miles Rd to Rt84) and back via I90 and 271, then Twinsburg to Warren via 82\305 and then 422 back.
Several triple digit blasts, and steady as can be. Beauteous. :mrgreen:
Unfortunately, the 93 fuel stuff is well over $4. Sheeesh.
Re: C6 Corvette
It's not even April and you got almost 200 miles on it, I'll take credit for that!!
Re: C6 Corvette
There will be no more complaining about the cost of gas on this forum. It's the price of having cool stuff! You didn't mention that it sips fuel like an 80s K-Car.
Re: C6 Corvette
Basement Paul wrote: Tue Mar 17, 2026 11:15 am There will be no more complaining about the cost of gas on this forum.
Im not usually much for rules, but i can get behind this! hahaha
Re: C6 Corvette
markss327 wrote: Mon Mar 16, 2026 1:42 pm Unfortunately, the 93 fuel stuff is well over $4. Sheeesh.
There are fees associated with being in the performance vehicle club.
Re: C6 Corvette
Bought with 41,7xx, almost a year ago, hit this mid April. :D
50K Milestone
50K Milestone
Re: C6 Corvette
Any updates on the trans?
- BP
Re: C6 Corvette
One year ago today......
As far as the transmission.....
The noise is a 'drone' when idling in gear. Both in drive and reverse. It's possible.... it could be the exhaust has a loose heat shield that's only vibrating at the in-gear idle RPM. If that's the case, I'll be really relieved.
I'm doing a Dextron VI 'drain and fill' in the next couple of days. Let's see what that does. I've already done a filter change last fall.
Otherwise, the 6L80 behaves normally.
Re: C6 Corvette
You need someone with a drive on lift, or a pit to drive over so you can check the exhaust while it's flat on the ground and in gear. I read a few guys complain about exhaust touching in places.
Re: C6 Corvette
I requested a copy of the original window sticker, and build sheet, from the Corvette Museum.
They finally arrived.
MSRP was $63K :shock:
All along I thought it was a 2LT, only to be pleasantly surprised its a 3LT!
The selling dealership (Voss Chevrolet) is still in existence. Might make a nice day trip Centerville Ohio, near Dayton.
Re: C6 Corvette
I was just looking at those earlier this week. That's really cool. If my Vette was stocker and nicer, I would get one of these for sure. But since it's a track dog...
Re: C6 Corvette
Huntington Valey Ohio PD. :evil:
One of my favorite rides, is taking Chagrin River Rd from Miles Rd in the south, to Ridge Rd (84) to the north. It's scenic and somewhat curvy in places. And, I never really paid attention to the speed limits, as I'm just cruising and not racing around. Well, on June 16th, I guess I must have feeling a bit spirited...
46 in a 35. $150.
At first, I was pissed. Speed camera. Bastards. :evil:
Then, I realized, had this been on I271, or I90, this could have been worse, much, much worse.... :mrgreen:
Re: C6 Corvette
Do your research, about 40% of photo speeding tickets are not paid. There is really not much they can do about it. Let me guess this is a fine only and not a points violation. Also Ohio has a law that says they have to post signs saying they are doing this (can't recall what part of the Ohio revised code this is).
I got one of these notices from city of Willoughby Hills about a year ago. I've gotten three or four notices but so far am just ignoring them. TBH sending me a notice two weeks later there is no way to tell how fast the car was going at that time.
Re: C6 Corvette
So far I have yet to hear any real repercussions from NOT paying one of these tickets. I have never got one, but likely would not pay it either.
