2014 Cadillac ATS Standard 2.0T AWD - Mostmint #46
Apparently its time to replace the Corolla with something that has a little more zip.
https://www.primeautosalesllc.com/detai ... /102223515
This car has a couple dings but its clean rust wise. It has 117k, brakes look new and are very responsive, and suspension is firm. I took a grand off the asking price since the differential needs rebuilt. It sounds like a bad wheel bearing but as various YouTube videos attest it is the differential - the breather gets plugged and the expanding/contracting cycle of the fluid eventually pushes all the fluid out of the diff.
It needs some other odds and ends but it seems like a good starting point for $6500.
the 2.0 makes 272 hp and the AWD weighs 3542 lbs
20/29 EPA est mileage
Re: 2014 Cadillac ATS Luxury 2.0T AWD
I like it! I think that engine is the same basic architecture as my Cobalt was. I think you got a great deal. Huge upgrade over the Corolla.
Hopefully I'll have it in racing condition for the opening Wednesday at KMP. And I kinda want to run it on the dirt dragstrip as well.
The Corolla has needed like nothing other than tires, air filter and oil/filter since I got it. That part will be missed. To be fair it did need some work when I first acquired it
I like the upgrade. The running gear is very similar to my 2016 Regal. Tons of front
tire burning torque there!
This one is RWD based, unlike your Regal. So the motor sits in there the correct way and not sideways. This one won't be frying the tires and should be a successful dirt racer as well. Hopefully it's just a tick slower than the Vette in the dirt.
Yeah, 2.0 turbo sedan.
Re: 2014 Cadillac ATS Luxury 2.0T AWD - Mostmint #46
Few updates:
1) Differential
3.27 gear
can buy a kit to replace the bearings and seals for as low as $70
can buy a new diff (Chinese I gather) for under $600
I found an ATS at local pull a part and it still has the diff in it. The car is wrecked in the front and the diff shows no sign of leaking.
The halfshafts and driveshaft all bolt to the diff so you can remove it without removing the halfshafts or even the tires
2) engine
is leaking oil - it appears to be the valve cover - still some work to diagnose 3) left rear is toed out
best guess is it had a minor incident in the LR and damaged a toe link. you can see a little damage on the quarter panel
4) tires and wheels
the tires I planned to replace, but it has 1 generic brand and three Continentals. They all have different manufacture dates.
225/45/R17
wheels seem to be pretty common so a used set of stock wheels can probably be had for about $200. Thinking I'll need a second set for snow tires
1) Differential
3.27 gear
2) engine
4) tires and wheels
225/45/R17
Had to learn how to jack up this car to pull the diff.
Differential is out - literally just unbolt the halfshafts and six bolts. I wasted some time because the rubber u-joint had metal sleeves that were slightly pressed in and I didn't understand this. After reviewing some videos I applied a few hammer taps and they came out. The thing is coated with fluid - kinda disappointed I didn't see when I was inspecting this car to buy it though the sounds on test drive saved me. It's just not a problem I was expecting on a Cadillac built in this century. Cam cover is off. Online research tells me that somewhere around 100k they start leaking. Mine is leaking pretty much all the way around the top but it really looks like the worst offender is the vacuum pump gasket. The hardest part of this job is reaching the bolts that hold the vacuum pump which is driven off the exhaust cam since the bolts face the firewall. Another oddity is the cooling line that runs over the cam cover and connect with the block through a hole in the cam cover. Had to drain some water out of the block so that wouldn't flow into the crankcase. Signs of a 10 year old car were prevalent: The gasket on the exhaust side got real crisp, under the hood I found some of the vacuum lines have already been replaced, and the suspect Y fitting in the cooling system has already be replaced, plastic tubes on the engine for PCV are very brittle so there is some work there, and a heat shield/sound deadener at the back of the engine is missing. Cam cover gaskets are on order. I pulled the plugs out. They are a bit black but this is likely due to the last half dozen times I moved it in and out of the garage without warming it up at all. They were AC 41-125 iridium plugs. The car is a bit sluggish when you first engage the throttle. On the assumption these are the original plugs I ordered another set. The rear tires had way too much negative camber and the LR was toed out quite a bit. I looked under there and played with the adjustments a bit - however one of the offset washers for the lower control arm on driver side was stripped so it wasn't moving with the bolt. I'll grab one from the car at pull a part. When the car is back on the ground I'll get to taking measurements and fine tuning it. This car has the same basic 5 link suspension configuration as the Challenger. New tires are on order. I was debating what combo of tires to get (summer/winter/racing) until I came across Michelin X-Ice tires for over half off at Tire Rack. If I'm doing dirt drags I can't see how snow tires can hurt, and with AWD I'm going to try them on the paved drag strip also. They are new old stock and I only drive like 5k miles per year. In time maybe I'll get another set of rims and summer tires.
So far I've only found a couple things in this car from prior owners - here's one of them. Before all this I ran it on a warm day and tried the AC which seems to be working well.
I've also learned that these come with a fold down rear seat though mine does not have that option.
I'm about halfway through the owners manual - there are a lot of bells and whistles on this car.
These direct injected Ecotecs can have problems with build up on the intake valves around 100k also so that's probably going to need an evaluation at some point.
Acquiring parts:
* Went to pull a part to fetch the differential. Also secured a wheel center cap, exhaust tips, special washers for the rear suspension camber adjustment, and three the door handle trim pieces. The rear bolt was gorilla tight I had to use leg power on the pipe extension on the ratchet to get it free. Otherwise it was a fairly straightforward procedure. * Went shopping for tires online and found Michelin X-Ice snow tires clearance priced for about $90 a piece. At this price I'll start with these - should help racing on dirt drags and will try them on the pavement also.
* Ordered a breather for the differential and obtained some plumbing to support it. Took some doing but I found a breather for a go kart engine that should do the job nicely.
* Acquired spark plugs
* Acquired new windshield washer bottle cap. Tried to locate this in the junkyard. There were at least six cars there with the same size opening but none of them had that cap. Almost all the other GM cars with the larger opening still had the cap.
* Cam cover gaskets are on order.
* Found a 13k page factory service manual online
Other:
* Cleaned up the differential and installed it in the car. Still need to connect the halfshafts to the diff.
* Cleaned up the cam cover and all the bolts. The main gasket surface is clean and prepped. This cover has one seal and many small gaskets - I will remove these when replacements are here so I put the new on in the same configuration as outgoing
* Saw a video on ATS where the guy was having problems with a vibration which dealer said was bent wheels. I was skeptical I had this problem but for good measure I checked. Sure enough all the wheels had small bends in the inside bead. Two of them had curb rash and were bent in slightly. Variances I'd guess are 1/8" ish maybe a little more.
Up on jackstands and work in progress The car has factory Brembo brakes! The door handle trim pieces - before and after
Other:
Differential install is complete
* differential breather is in place. I ordered one for a 5/16" fitting but it ended up 3/8". Quickly overcame that with a change of attachments.
* turns out the bolts holding the halfshafts to the diff are one-time use torque to yield. I torqued them to 55 ft/lbs and will monitor them * decided to check the magnetic plugs in the diff. both had fine metal on them. fluid level was good and looked good. Other
* tires are mounted, balanced and on the car
* installed the good offset washer and took some big swings at adjusting the rear toe and camber. It's a lot better but still need a good 4 wheel alignment for the last bit. I need to be able to move the car to get the suspension to settle after adjustments and it's not running. Also IDK yet how to easily get this car in neutral without starting it which I'm not doing with the engine apart * I've gone as far as I can with the cam cover - some of the gaskets still are not here yet. I took time to replace the brittle plastic tubing in the PCV system
* The cam cover has been off this car before. Some of the pieces in back for insulation and holding on the engine cover are missing. I also notice oil leaking where the lines connect to two of the PCV valves. These observations make me wonder if there is a problem with the PCV system not operating properly. I understand how the air is supposed to flow, and some things to check in the system to make sure its working.
Had some drama obtaining the proper cam cover gaskets.
If you need to buy GM parts I would suggest avoiding GMpartsgiant.com. No one sells all the gaskets you need in a kit. Aftermarket kits all seem to be missing the seal for the vacuum pump. Looking at the pieces it seemed like the prices piecemeal for GM parts was not that much more so I figured out what I needed and ordered a la carte from GMpartsgiant. They divide the order into two parts - the first part they ship right away and 5 days later its here. The next part requires me to confirm that they are special ordering and these parts cannot be returned. I'm like fine just send them. This is like 4/16. I get an estimate of delivery between 4/18-4/24. On 4/24 the parts are not shipped yet so I contact them to see if I can cancel. They don't have the parts yet so I might have a chance. They said no. Well I signed off saying no returns were OK but they are not on the hook to deliver in a specific time. As of this writing the parts are not shipped yet.
I decided to get an aftermarket kit - Autozone had a Mahle kit that had all but the vacuum pump seal, but that had arrived fortunately. It was not in stock so I ordered it online on 4/24. Mistake. Order confirmation said they would send me an email when the parts were shipped. Near the end of business day I called the local Autozone and told them I needed the same kit, which they would have delivered by the morning. 10 minutes later the Fedex guy delivered the first kit I ordered from Autozone. Still waiting for the email on that one.
So the gaskets were installed in about 2 hrs. There is some RTV to be applied in a few spots I'm waiting for that to cure to drive it.
In the meantime I synced my phone to the car. Unfortunately while the car can do calls through bluetooth it will not allow me to stream music from the phone through bluetooth. I have to connect to a USB port in the center console. My Corolla which was much cheaper new can do this.
Anyway test drive tomorrow!
I've been driving it for a week or so now.
I was quite happy on the first test drive to find the junkyard differential is nice and quiet. The jury is still out as to whether these rims are round enough to have no vibrations. It seems the first time at highway speeds there is some, but nothing at all below 50 mph. There are some suspension clunks in the front on rough surfaces (stabilizer link or maybe a strut) but it feels solid on cornering and braking so I can investigate later. The first time I stood on it at highway speeds on dry pavement the traction light came on! I can only guess the snow tires are tricking the traction control a bit, as it didn't feel at all unstable. Also its so quiet! There is a baffle in the intake to keep that quiet - that will be the first thing to go. I was a bit disappointed to see it still leaks oil. I looked underneath to confirm there were no problems down below - I have work to do to be able to see where up top it might be leaking. There is very little clearance and my lighting/mirror situation is not good enough. It does not appear to be leaking when driving, and it does not leak for a while after shutting it off, so it's unclear the cause. I suspect a little pressure left over in the crankcase but until I know the source I can't say for sure.
Being a Cadillac I had certain expectations about the technology in the car and features it would have. I am a little surprised that it does not have a trip odometer. The owner manual shows it as an option in the ATS but mine does not have it. Also, the bluetooth interface will not allow me to play music from the phone - apparently none of the ATS models had this in 2014. My Corolla has this and it's only one year newer. In this car it seems my option is to treat my phone like an iPod and connect it with a cord.
This morning I did a little testing in prep for its racing debut. Figured out how to put it in sport mode. Also I can confirm the stall speed on the converter is not less than 2700. Letting the computer shift the car redlines at 6500.
The parts from GMPartsGiant finally showed up on 5/4.
Observations from my first trip to the dragstrip with this car
1) Tinted windows look cool but they are terrible at night. Coming to a 4 way stop in the countryside I cannot see out the side window. If a car has headlights on I can see it but I find that extra filtering disconcerting. The tint has to go.
2) The headlights are weak and not aligned perfectly. One of them needs a bit of adjustment. The Corolla daytime running lamps have a lot more light coming out of them than these.
3) No oil left on the floor overnight after almost 3 hrs of driving and half a dozen dragstrip passes.
4) As the differential is warming up I swear I can smell a bit of fluid. My breather is apparently doing its job but its odd that the smell can work its way back into the car if the window is open. I'm going to keep an eye on it to make sure it not leaking but otherwise this is not really a problem.
5) I ran most of the passes in sport mode. When they switched to 1/8 mile passes, I let off at the end and the car would not upshift. I switched back to touring mode after this happened and it went back to normal on the return road. Unclear if this is normal behavior
6) When tires are cold the car will vibrate in the front for a few minutes, but after that it's fine for regular driving. On the track I felt vibrations again near the traps
7) On track it makes a gear shift right before the traps. I'll have to decide if it's worth it to manually override and not do that.
With traction control off it will not spin the snow tires at all, even with a launch RPM of 2700.
9) Also noteworthy is the car will stay in sport mode until I change it - even if you shut off/restart the car.
10) I have not figured out how to put it in gear without starting it, but once started I can put it in neutral and shut off the car.
11) The first few passes seemed to produce fairly consistent results, though hot lapping cost almost a tenth. I'm going to explore running it at operating temp/on the thermostat to see if that helps consistency.
12) With the RPMs up the lanuch time is somewhere between the 2nd and 3rd yellow so I'll have to explore ways to speed that up or slow it down. Might try lower starting RPMs to see if that helps.
I suspect this is completely normal in sport mode, especially after you were just flogging it for 660', it just thinks you're slowing down for a turn and will be jumping on throttle again soon after the apex.
