How to extend a spray straw
Postby wxo » Fri Jan 27, 2017 5:07 pm
If you need a longer straw to get some spray lube to an inaccessible place, I found an easy way to do it. I piece of insulation from number 12 electrical wire is the perfect size to use as a connector for adding additional length to the normal straw you get with a can of spray lube.
Return to “Reference / Tech-Tips”
Who is online
Users browsing this forum: No registered users and 1 guest
