Project: Cheap Bastage - Distributor Repair
Posted: Sun Dec 27, 2009 9:34 am
I don't know what my "issue" with points distributors is lately, but I am tired of messin' with them and especially so when they are HARD to get to like the one in my '47 Ford truck.
I scored a couple HEI type dizzy's to cut up and in the process ended up with this one sporting a tach drive - not sure I really NEED that but hey the price was RIGHT!
So this is what I started with - the shaft was too short AND messed up so I went ahead and just cut it off. BTW this is an old GM Mag Impulse dizzy that's been cut down to run in a mopar - I'm changing it over to fit in my 392 hemi:
After cutting off all the "bad" shaft I turned it down with a pilot .001" over size. And made a stub shaft to be pressed on & welded. Stub is oversize:
Post welding:
Checking for true:
Finish cut bring stub OD to proper size:
Indexing rotor's (new to old) so the dizzy will drop right in without having to fiddle with the intermediate shaft later.
Lastly I made up a small collar that I will pin on just like the origional:
I don't like the adapter sleeve that's on this. Probably me just being paranoid, but it wasn't made how I'd do it - so I think I'm just gonna go ahead and make it over.
So there's one more down! Nothing wrong with points - I'm just getting lazy as I get older and these old hemi's all have dual points and are not easy to adjust! So AWAY they go!!!
Racin'Jacin
Post welding:
Checking for true:
Racin'Jacin
