Project: Cheap Bastage - Distributor Repair
Racin'Jacin
Postby Racin'Jacin » Sun Dec 27, 2009 9:34 am
I don't know what my "issue" with points distributors is lately, but I am tired of messin' with them and especially so when they are HARD to get to like the one in my '47 Ford truck.
I scored a couple HEI type dizzy's to cut up and in the process ended up with this one sporting a tach drive - not sure I really NEED that but hey the price was RIGHT!
So this is what I started with - the shaft was too short AND messed up so I went ahead and just cut it off. BTW this is an old GM Mag Impulse dizzy that's been cut down to run in a mopar - I'm changing it over to fit in my 392 hemi:
After cutting off all the "bad" shaft I turned it down with a pilot .001" over size. And made a stub shaft to be pressed on & welded. Stub is oversize:
Post welding:
Checking for true:
Finish cut bring stub OD to proper size:
Indexing rotor's (new to old) so the dizzy will drop right in without having to fiddle with the intermediate shaft later.
Lastly I made up a small collar that I will pin on just like the origional:
I don't like the adapter sleeve that's on this. Probably me just being paranoid, but it wasn't made how I'd do it - so I think I'm just gonna go ahead and make it over.
So there's one more down! Nothing wrong with points - I'm just getting lazy as I get older and these old hemi's all have dual points and are not easy to adjust! So AWAY they go!!!
Racin'Jacin
Return to “Projects”
Who is online
Users browsing this forum: No registered users and 1 guest
