Page 2 of 2
Re: 1969 Pontiac GTO convertible
Posted: Tue Apr 24, 2018 5:54 pm
by TheRookie
So the GTO is finally home and figured I'd do a brain dump since it's been a while. I knew I had to invest a little for a "100 point inspection" and address the top items. The shop basically had to replace front/rear shocks, adjust rear 6-link suspension, put front springs back to stock, replaced master cyliner, and replaced all tires w/ white letter Radial TAs. Also included a tune and tightening a lot of loose stuff. Now it drives really well, but still runs a little rich.
At Carlisle, I ended up with the following treasures: Rearview mirror, mount and boot since the old one is foggy. A couple headrests in good shape. Window switches and door handle for passenger side that are a little pitted. And finally, a couple vacuum actuators for the hideaway lights. I think I can do most of that with my minimal skills.
Still researching and thinking about my fuel system. Option 1 is downsize from Holley 750 DP to a 650 DP or 670 Avenger. Option 2 is rebuild the original Rochester QJ. I sent pics to GMJohnny and he's concerned about the condition of the rusty linkage. Option 3 is going EFI, likely Holley. It's about $1600 in parts between the Sniper kit, EFI tank, pump, line, etc. Despite cost, leaning towards #3 for set and forget it.
Last, but not least, I plan on taking it to a highly recommended body shop near me to see what options I have. I have a quarter size bubble on the hood but pretty sure it's solid overall. Not sure if they can match, touch up, slap a clear coat on it or what. Definitely needs body panels adjusted too. More to come and not highest priority. I just want to know.
Posted: Wed Apr 25, 2018 7:21 am
If it's running rich, you might just jet it down a size or two on the primaries. Is that a 400 engine?
Posted: Wed Apr 25, 2018 8:23 am
by TheRookie
Yeah, it's a 400 with a mild build. The shop dialed it back as much as possible.
Posted: Sun Jul 29, 2018 11:16 am
by TheRookie
Hopefully find some time soon to slap on some new parts, especially when it’s cooler. Need to get the tranny checked out too. 1st gear makes a weird creaking sound. All others are ok. In the meantime, enjoy some great pics of the wedding getaway car.
Posted: Sun Jul 29, 2018 11:18 am
by TheRookie
3 more. Hit the 8 pic max.
Posted: Fri Feb 08, 2019 7:09 pm
by TheRookie
I think I’m putting this up for sale. Just finished getting tranny rebuilt after first gear starting knocking. Not enough time for two toys.
Posted: Fri Feb 08, 2019 8:17 pm
The right weather should be coming soon.
Posted: Sun Mar 17, 2019 4:50 pm
by TheRookie
Well, it was fun while it lasted, but the GTO went to a good home a couple weeks ago. He also has a 67 GTO ragtop, 67 Firebird, and 77 Trans Am. New home is a little outside Detroit.
Posted: Sun Mar 17, 2019 9:14 pm
by Racin'Jacin
Homerun!!!
Posted: Mon Mar 18, 2019 4:49 pm
That was a nice car, but the truck is probably more fun. So if you're going to keep one, you made the right choice.
Posted: Tue Mar 19, 2019 7:56 pm
Owned a 69 GTO convertible- check
