New rule or new to me?
According to the Thompson site, I need to have a helmet if I plan on going 13.99 or quicker, eh? Looks like I need to invest. I didn't have one last year, but perhaps they don't enforce it much. Thoughts? BTW, its been a while since I bought one. Where can I get one at a decent price? Bike shop?
I got mine.
After time trials, I was asked if I had my helmut. As luck would have it, I did. It's very old, hope no one notices.
I think this is a new rule again this year. There was a time when you needed a helmut no matter what you turned.
DOT Approved?
The 13.99/brain bucket rule has been in existence as long as I can remember. Not so enforced during time runs, but in eliminations, the start guy, will check your dial, and look for the helmet.
Some other rules that come to mind-
- If running slicks, you'll need a drive shaft loop - front, I believe within 4in of the U-joint
- All carbureted cars are to have two (2) throttle return springs.
- The obvious seat belts
- 11.99 you'll need a flame retardant jacket
- 150mph will require a p'chute.
- 10.99 requires a 6 point cage - or just a hoop.... not sure.
2012 Impala LT 3.6 VVTDI
300hp - a bit much for FWD!
Inspection, what inspection ????
How many times has a 'tech' actually looked under the hood of your car? Mine (the '63), twice. Both times, at 42! I think, if we ran points, i.e., Saturdays, we'd see a more complete 'inspection'.
I understand some older helmets are now out of spec -just by date of manufacture - old.
There have been various crackdowns on the rules. One year I happened to be there the weekof inspection and they crabbed about my battery box. So I went through a lot of hassle to change the mount configuration, and also add the driveshaft loop. Never again did they check!
I remember when TDR started with the helmet rule, and I always thought they required it. My guess is spotty reinforcement is why you have not been called out on it. Have you seen the guy sho is the starter - last time I was there he did not look like the sharpest knife in the drawer. Did you run truck class? Maybe he isn't thinking trucks go that fast so he quits paying attention.
I think 42 requires the helmet once you go a certain ET, but since the TDR rule I have been in the habit so I always take one.
