cheap car racing
Re: cheap car racing
It was a "Fun Day" at Nelson Ledges Raceway. That landscaping above was done by Mostmint
shortly after the Track Car left us on our own. I was riding with Tiresmoke and was able to
capture the moment. Nice save!
Pre race ...........................1st on track...................chalk talk
Beefstro..........................Diploma...........................safety
I was given access to the control tower, cool stuff.
Here is a video of the Mostmint Race Team's car in action on the front straightaway.
http://www.youtube.com/watch?v=6Vtug2XycU4
Good fun!
Good fun!
Great clip Fred! That thing sounds good!
A couple laps from the tower:
[youtube]http://www.youtube.com/watch?v=4WxFDR3_cXY[/youtube]
Here's one of my sessions in the car. Andy, you can see where I dropped the left side off exiting the carousel at 2:30.
[youtube]http://www.youtube.com/watch?v=A5o1D7_1QF8[/youtube]
Nice save. You still had most of the car on the track. The sounds were very similar to mine - just less of them since yours was shorter.
I haven't looked under there yet to see if I did any other damage (other than possibly the tire) in my off track experience. I can't see how yours could have hurt anything.
Is the Shoo-makka Landscaping Company one of the sponsors of this forum?
Most Mint gave a brilliant display of driveway edging at speed!!!
Oh Dave, I found you another car to drive on the race track!!
http://cleveland.craigslist.org/cto/2333037014.html
Too good of a bargain to pass up!!
I think I need a sponsor.GMJohnny wrote:Oh Dave, I found you another car to drive on the race track!!
Over the last couple days I have made some interesting observations about the cars we did not pick:
1) The Fiero
Spoke with a west coast Fiero team and he pointed out the troubles with inexperienced drivers and the wet, he also mentioned inherent problems with the brakes (the rotors are not vented - design taken from the Citation he said). Furthermore the Fiero we looked at was one of only a few to have a best time at Nelsons over 1:40 per lap. Most were in the 1:30 range, about 20% in the sub 1:30 range. Pretty sure we saved ourselves a lot of work to bring that car up to speed.
2) The Escort
Looked at the lap times from the Charlotte race. The batmobile (Saturn SL2) turned a best lap of 1:38 and finished 14th. The Escort turned a best lap of 1:53 and finished only 18 laps - in 45th second to last.
1) The Fiero
2) The Escort
I'd have to think the Fiero near you was hampered on lap times by the automatic, either from sub-optimal gearing with a 3-speed or a crummy torque converter, or both. And we were right to be suspicious of getting a Ford product!
Its not often when buying a used car that you have after-the-fact info to validate the decision, and its obvious we've made the right one so far. Yay us!
So when's Bridgestone Day?
[youtube]http://www.youtube.com/watch?v=gawWVrFbR0o[/youtube]
The sun glare is pretty bad with this camera, but if you start watching at 6:25 you can see Joey chasing me down. I believe part of the reason he is closing so quickly is I was working the outside line on several corners as he was approaching.
here we are on Friday night:
and on Saturday
windows got installed too
Sunday started with installing the head:
and ended like this
and on Saturday
and ended like this
Here is some interesting info on the Saturn:
http://www.saturnspot.com/showthread.php?t=28298
Here is the content from the thread:
Here's the details:
1992 Saturn SC
156,000 miles
Engine
1.9L LLO 4 cylinder, Multi Point Injection, DOHC, chain driven
4-2-1 tubular exhaust header wrapped with DEI header wrap
Hand bored throttle body
Hotshot short ram intake, wrapped with insulating material with K&N cone filter
Prothane polyurethane motor mount inserts
Odyssey PC680 battery (680 CA, 12v, weighs 14.5 lbs)
Air conditioning system removed
2†mandral bent cat-back exhaust through a Thrush Magnum Glasspack and tunable SuperTrapp muffler
Transmission/driveline
Fidanza 8 lb aluminum flywheel
ACT 6 puck race clutch
New clutch hydraulics
Corvette lug studs on front axles (to be used with spacers if needed)
Hardened roller tapered front bearings
Suspension
H&R Sport Springs 205 in-lbs front/195 in-lbs rear
KYB GR-2 gas charged struts
SPS 3 way adjustable 16mm rear sway bar
Energy Suspension graphite impregnated polyurethane master bushing kit
Adjustable front and rear strut tower braces
Saturn factory 13 lb “sawtooth†15â€Âx6â€Â, 4x100mm, 50mm offset, 56.1 mm hub bore wheels
205/50-15 Toyo RA1 tires- shaved. I picked these up used at the Run Offs in ’06.
Brakes
Front pads- Duralast for street and autox, Hawk Blue for track use
Goodridge stainless steel brake lines
Russell Speedbleeders on front
ATE Super Blue DOT 5 brake fluid
Interior
Most of the interior has been stripped- carpet, padding, trim, headliner, radio
Corbeau Forza racing seat with FIA Homologation
Corbeau non-height adjustable seat track slider
Sparco Clubman 4 point harness
MOMO drill on pedal covers
Manual radiator fan switch
Here's the details:
1992 Saturn SC
156,000 miles
Engine
Suspension
Brakes
Interior
Am I crazy, or is that *our* car?? I mean all the descriptions sound like everything we have. (when we bought it)MostMint wrote:Here is some interesting info on the Saturn:
