It started to develop a miss this week. It would only do it on start up, than it clears up. I guessed fuel system. Drove the vr to work instead.
Today decided to take the 8v. The miss was horrible and not clearing up. Aww Sh**, guess I'll have to drive the VR, again.
After work I ordered a fuel filter. Thought I would start on the easy fix, the cap and rotor. Hoping it wasn't fuel related because I wanted to play with the other car. That was it! A little sand paper on the contacts fixed it (temporarily)
I cant figure out why these things (8 valvers) go through distributor caps. Every year I replace a set. At least its cheap and easy.
1991 MkII GTi 8v
Re: 1991 MkII GTi 8v
I dont think so. I will check them though when I put on the new cap and rotor this week. Thanks, I never thought of that.Maverick wrote:Plug gaps too wide?
Is your distributor shaft loose?
The distributor is good. A New Bosch went in when I put on the head. I also had that thought years ago but the bushing in the old one were good.
Supposedly the bushings outlast the motor. I replaced mine because the Hall sender went bad. Hall senders have been NLA for a while (they were only $30)
Distributor is 230ish- guess thats why they made that change
